Sourcing “Maf gasket” & “full vacuum pump gasket set” ??
Davill9
Surrey
Hi everyone,
can anyone recommend somewhere to get the best quality non main dealer gaskets in the Uk for:
1) Maf sensor,
2) Brake vacuum gasket set,
3) the o ring on the small hard pipe that comes off rocker at front, between pcv on right, and oil filller on left. (Still unsure what it is for tbh atm) am guessing the exhaust valve solenoid takeoff??
main dealer don’t sell, so it has to be aftermarket and the parts themselves are fine, so doesn’t require full replacement.
Silicone sealant is not really an option as I prefer the gasket rather than a lash job if possible.
Oh and they are all leaking slightly on smoke test hence the need for replacing.
Thanks in advance.
Has recommended mr o ring on eBay for the brake pump gasket kit so unless anyone has any bad stories on them I will get asap
does anyone have suggestions for maf gasket?
the maf part no is 06f 906 461A
And picture of shape will be posted in a bit....
This is maf shape, for sourcing a gasket
Mr. Oring on eBay.
nearly a year on and still no leaks and dry as a bone !
403
9
447
mjr901
M
319
