Spacers
bobby_s3
Hi,
I’m looking to fit some spacers on the RS3.
I ordered some from eBay, but I have the issue off the inner lip from the hub being too long and hitting the spacer so it isn’t sitting flush.
Anyone know which spacers are the correct ones?
bobby_s3
Are you fitting to the front or rear? Do you have your hub lip length?
Damian @ DPM Performance
I’m looking for 10mm all round.
I don’t have the hub length to hand but I know that is the issue when I ordered the previous set of wheel spacers.
bobby_s3
Was the issue with the rears only or both front and rear? I'm guessing they were cheaper spacers?
I didn’t try them at the front, just assumed it would be the same issue all round.
I’ll try them tonight at the front to see the outcome.
But ye they were cheaper ones, MTEC?
bobby_s3
When you check if you can get the hub lip depth as well.
So just checked and it’s 12mm.
I have attached a picture
45bvtc
The Older I Get The Better I Was
Supporter
Gold Supporter
Them brake-disc-hubs could do with a polish, bobby, before you fit the spacers:
Just sayin'...
45bvtc
Supporter
Gold Supporter
They do look a lot better polished. What product did you use?
Spigot depth is 11.6mm measured on BLUEY, Bobby, just measured...
And to polish is quite easy; Solvol Autosol, a 30mm dia buffing wheel, and an electric drill - and them are 2012 (47i6) brake discs...
