Speakers Clipping/Cutting/Crackly after installing Pioneer AVH x8800BT
LanceG
DIY until I break it LOL
London
As per title.
I installed a double din unit and since then, the front speakers have started clipping at around volume 17
I assumed this meant I needed bettter speakers so I got some Alpine components just to stop the clipping but guess what
clipping still exists... anybody experienced this before?
I take it didn't do this before I would start over again. But wire fronts up first on there own and do a volume check process of elimination
It didn't do this before no.
Tried that last night, still crackles and clips - When I fade to the left or right, I can turn up with no problems, but the problem is when everything is balanced and I try to turn it up... sounds dreadful.
The factory unit? Not since installing the new speakers no.
I'll give that a try in the week to rule out a dodgy head unit?
But I've used this HU in my previous 3 cars, one of which being an Audi A3 but with Bose so I'm a bit as confused why I'm having problems with this car
Sent from my CLT-L09 using Tapatalk
As per title.
Usually this type of issues arise when you use poor double din adapters/components. What adapter are you using? I’m using the setup from Connects2 with zero issues.
I don't even remember.
I'm sure it's a Connect2 one but not 100% as I didn't go to my "go to" car audio store to get it
I need to get one with steering wheel controls anyway so a new one will be on order soon along with the 2 piece facia which avoids that square cut out in the install, cleaner finish
Good shout, will let you know if that fixes it or not!
Give Dynamic Sounds a call if in doubt. They are based in Wandsworth.
Do you have a Bose or non Bose setup? I’ve done a double din conversion too.
No Bose badges on any of my speakers - old speakers were balupunkt, small sub in the boot left hand side and I have the iso connector
Is that half bose?
That's my "GoTo" store lol
This is what I'm going to buy
https://www.dynamicsounds.co.uk/con...-stalk-control-adaptor.html?search=CTSAD007.2
I've got the same harness but without the steering wheel control and the other black boxes. (WTF is that other big black eyesore)? I think that's where I've gone wrong :blownose:
the saying is true, "haste makes waste" I should've waited for the weekend or just paid online but I was eager and impatient! :scared2:
Is that half bose?
Yes. You’ve got the exact setup as I do.
I got this fascia:
https://www.dynamicsounds.co.uk/con...le-din-car-stereo-fascia-fitting-adaptor.html
Then this adapter:
https://www.dynamicsounds.co.uk/con...-tt-steering-wheel-stalk-control-adaptor.html
Works with both Bose and half amplified systems. Supports ISO and quad lock adapter.
If you want Hey Siri integration you can buy a version up that will activate Hey Siri from the steering wheel.
same fitting kit I'm looking to get!
Looks so much nicer than the one I currently got with the square fascia that goes in the middle.
You did a brilliant job!
