Yes, it can (Did mine when I wrapped the sourroundwith Vinyl). Look closley at the edges on the underneath, you will see thin plastic lugs all around that clip into (your) wood veneer sourround. Be careful as they are fairly fragile. It will pop out (let me know if you have trouble, I can take pics of a spare I have somewhere).
G
Let me dig mine out this morning and photograph it so you can see the clips (Don't try and lift it without disengaging these). I can't see your clips in the photo or I would circle them. Give me a little while....I'll be back.....
Strange - Must be fixed then and the Tabs for Auto boxes? Sorry, I tried...
If I remember correctly from doing mine, I had to drill the top off the silver plastic spot weld type bit, just enough to be able to push it free, then the trim came off with the wood effect skin, then just pushed out
