timb80
Hi, I have an Audi A4 (B9) 2016 model and recently got "Steering: fault. Please stop vehicle" error come up on the dashboard out of the blue after a drive and now the car won't start or even turn the ignition on. There were no signs of any issues with steering before the vehicle had been used earlier in the day. The electronic hand brake is now stuck as the ignition wont switch on and can't move the car at all and face the prospect of getting it towed.
OBDeleven scan shows static fault code P160A00 with the 2B steering column lock module but doesn't seem to be able to clear it. I've done some searching but doesn't seem to be common. Does anyone have any tips or have come across this problem before? Can this be fixed locally or does it need to go back to Audi?
Thanks, scan log below
Code:
OBDeleven data log
Date: 2021-04-07 20:22
VIN: WAUZZZF47GA068096
Car: Audi A4
Year: 2016
Body type: Avant
Engine: CVNA 110 kW (150 HP) 1.4 l
Mileage: 71176 KM
2B Steering Column Lock
System description: ELV-MLBevo
Software number: 3Q0905861A
Software version: 0032
Hardware number: 3Q0905861A
Hardware version: H05
Serial number: 15000175666002
ODX name: EV_ELVMarquMQBB
ODX version: 001007
Long coding: 0000000000000000
Trouble codes:
P160A00 - Ctrl. module faulty
static
Date: 2021-04-07 17:38:34
Mileage: 71177 km
Priority: 1
Malfunction frequency counter: 1
Unlearning counter: 255
Result lock conditions: Invalid
ESCL locked: No
ESCL unlocked: No
Lock sensor: not activated
Unlock sensor: not activated
Error mode 1: active
Error mode 2: not active
Clamp S: Off
Clamp 15: Off
Clamp 15 status: valid
Remotestart: not active
Driver door: open
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: Off
Highside unlock: No
Motor break: active
Activation lowside unlock: On
Activation lowside lock: On
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd true
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: No
Signature IMS OK: No
IMS responded: No
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 11.6 V
UMotorBridge: 0.0 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition met
Lock condition timeout vehicle speed: Condition met
Lock condition Mode1: Condition not met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition met
