As above, at slow or fast speeds, and not on full lock either. Could this be the Power Steering Rack/Pump??
you have to remove the panel that also covers the windscreen wash tank and its under there, with a green lid. I just put halfords powersteering fluid in mine... its all the same
bad advice J! that's going to cost you in the long run. unless you have bought the right stuff and not explained it properly!
VAG power steering fluid is not the same as other cars. Most cars just use ATF, which is about £5-6 a bottle in halfords. VAG stuff is actually mineral based, and if shopping in halfords, you'll need their central hydraulic fluid, at about £14 per bottle!
I put normal ATF in mine a few years ago, and about 9 months later the seals in the rack went.
Green mineral stuff from GSF is only about £7 for 1.5 litres
GOO4OOOM2 is what you want nothing else .
