Suspension torque specs
rihardsss
Been looking at bushings on control arms, coil springs, shocks and decided that I want to redo whole front suspension + shocks, coils on back. Looked around and found Koni schocks, Eibach coil springs. Gonna look up control arms, tie rods, sway bar links etc. But will need torque specs for all those bolts going in there. Anyone can help with that? Is there a good place where can look up torque specs for Audi A7 or need to buy some book for it?
Best bet is to use erwin, elsawin & use your vin to get the exact specs as even of the same chassis, year differences in bolts is possible, thus torques also.
Reactions: rihardsss
Thanks, will look into those. Sounds like just what I need
Disregard below
i read too fast and thought it was part numbers you were after.............
what about www.oem.pc
dang it , has this site been taken down...pity
try this this seems to work similar
see pics if this is what your looking for.
Any opinions on Meyle HD control arm set? When catching right deal could get this set for £450 from AutoDoc. Also looking at Lemforder, just need to pick those up 1 by 1 instead of full set.
Screenshot 20211102 010035  01
Personally I would avoid Meyle, I would look for Lemforder
