Just came back from a dealer major service. Noticed a oil leak on the garage floor. Checked the oil and found this...wonder how much damaged has been caused
My concern is I drive 75 miles home with it like that. Will call them tomorrow and see what they say. Very disappointed a main dealer did this. Even more disappointed at the amount of damage to the seals, cat that could have happened
Its not overly overfilled, as said above it might be residual. Let it settle, clean and re-dip. AFAIK oil at the dealer is electronically measured - may be wrong though.
That’s a cold dip. Wiped and dipped again. Bare in kind I have also lost oil driving home from the dealer and whilst sat in the garage. Leads me to believe it was very over filled initially. ****** off that a dealer could be so negligent. Had a cam belt and water pump. Haldex and brake fluid changed as well. All done in less than 5 hours. Makes me wonder what they actually did?
