Transmission Output Speed Sensor / Transmission Control Module
VrX
Kent
Along with suspension got a failure for ESP light being on for MOT (really bad timing as obviously wouldn't have taken for MOT if light was on)
Basically never had this on before and wasn't on after test but sure enough VCDS showing 2 codes during MOT yesterday...
On transmission... 2228 - Transmission output speed sensor (G195)
On ABS... 01315 - Transmission control module
Anyone have any experience in these two? Have been cleared and not returned since, is it likely something on brake test that could of caused these (or any other test)?
EML isn't a MOT failure.
Please provide a full autoscan from your vehicle inside [c0de] [/c0de] tags replacing 0 with a o
Sorry... being an idiot there... ESP not EML
Didn't notice it didnt connect to engine before clearing, 2nd attempt connected fine but code already cleared so no idea what that one was.
Code:
Sunday,27,August,2017,12:24:22:05031
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WAUZZZ8K59A164078  License Plate: KR58DGU
Mileage: 233040km-144804mi  Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 52 53 55
  56 62 72 77
VIN: WAUZZZ8K59A164078  Mileage: 233040km-144804miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans (J217)  Labels: 0AW-927-156.clb
  Part No SW: 8K1 927 155  HW: 0AW 927 156 H
  Component: 0AW 27 TDIRdW H01 0001
  Revision: --H01---  Serial number: 0000000186
  Coding: 000001
  Shop #: WSC 06325 000 00000
  ASAM Dataset: EV_TCMVL381 A01015
  ROD: EV_TCMVL381_AU48.rod
  VCID: 71EE4DEBA0BABDB6A2-8024
1 Fault Found:
2228 - Transmission Output Speed Sensor (G195)
  P0722 00 [236] - No Signal
  MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
  Freeze Frame:
  Fault Status: 00000001
  Fault Priority: 2
  Fault Frequency: 1
  Mileage: 232989 km
  Date: 2017.08.26
  Time: 11:41:06
Address 03: ABS Brakes (J104)  Labels: 8K0-907-379-V1.clb
  Part No SW: 8K0 907 379 AE  HW: 8K0 907 379 AE
  Component: ESP8 front  H04 0240
  Revision: --------  Serial number: --------------
  Coding: 1A0500
  VCID: 7CF06CDFFFF8C0DE01-8028
1 Fault Found:
01315 - Transmission Control Module
  013 - Check DTC Memory - Intermittent
  Freeze Frame:
  Fault Status: 00101101
  Fault Priority: 6
  Fault Frequency: 1
  Reset counter: 247
  Mileage: 232989 km
  Time Indication: 0
  Date: 2017.08.26
  Time: 11:41:07
  Freeze Frame:
  Hex Value: 0x0300
  Hex Value: 0x4A82
  Hex Value: 0x0226
  Hex Value: 0x25B2
  Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393)  Labels: 8K0-907-064-05.clb
  Part No SW: 8K0 907 064 C  HW: 8K0 907 064 C
  Component: BCM2 1.1  H80 0145
  Revision: 00002001
  Coding: 011100
  VCID: 306888EF6330F4BEED-8064
  Subsystem 1 - Part No SW: 8T0 959 754 D  HW: 8T0 959 754 D
  Component: FBSAUDIB8 IDG  H37 0060
  Subsystem 2 - Part No SW: 8K0 905 852 D  HW: 8K0 905 852 D
  Component: ELVAUDIB8  H36 0041
No fault code found.
Address 07: Control Head  Labels: 8T0-035-7xx-07-H.clb
  Part No SW: 8T0 035 729 N  HW: 4E0 035 729
  Component: Interfacebox  H43 5170
  Revision: 00000000  Serial number: 329J1087619746
  Coding: 0000002
  VCID: 4480D43F0788781E39-8010
  Subsystem 1 - Part No: 8T0 919 609
  Component: E0380 BedienteilH08 0100
  Subsystem 2 - Serial number: 00000000177241
  Subsystem 3 - Serial number: 0120.10.080000000100010255ÿ
  Subsystem 4 - Serial number: 010255ÿ
Address 08: Auto HVAC (J255)  Labels: Redir Fail!
  Part No SW: 8T2 820 043 S  HW: 8T2 820 043 S
  Component: KLIMA 3 ZONEN H06 0150
  Revision: D0000000  Serial number: 01211020080172
  Coding: 36040000
  VCID: 428CD227DD9C762E0B-8016
Address 09: Cent. Elect. (J519)  Labels: 8K0-907-063.clb
  Part No SW: 8K0 907 063 C  HW: 8K0 907 063 C
  Component: BCM1 1.0  H22 0253
  Revision: 04022001  Serial number: 00000000149452
  Coding: 260050914134AF211601000000001D0D009D430800010141000000
  VCID: 2F6A8B937E0EEB46F4-807A
  Subsystem 1 - Part No SW: 8K2 955 119 A  HW: 8T2 955 119  Labels: 1KX-955-119.CLB
  Component: WWS 221008  H05 0070
  Coding: 00FD11
  Subsystem 2 - Part No SW: 8K0 955 559  HW: 8K0 955 559  Labels: 8K0-955-559.CLB
  Component: RLS  H04 0003
  Coding: 025028
  Subsystem 3 - Part No SW: 8K0 941 531 AA  HW: 8K0 941 531 AA
  Component: E1 - LDS  H07 0080
1 Fault Found:
03207 - Charisma Switch Module
  004 - No Signal/Communication
  Freeze Frame:
  Fault Status: 01100100
  Fault Priority: 3
  Fault Frequency: 1
  Reset counter: 202
  Mileage: 232892 km
  Time Indication: 0
  Date: 2017.08.15
  Time: 16:39:00
Address 0E: Media Player 1  Labels: 4E0-910-111.lbl
  Part No SW: 8T2 035 110 C  HW: 8T2 035 110 C
  Component: MP3-Changer  H44 0390
  Revision: 00044003  Serial number: AUZ5ZBH8638183
  Shop #: WSC 00000 000 00000
  VCID: 2B529F838A169766D8-807E
Address 15: Airbags (J234)  Labels: 8K0-959-655.clb
  Part No SW: 8K0 959 655 B  HW: 8K0 959 655 B
  Component: AirbagVW-AU10 H27 0410
  Serial number: 0038JD1C1MB4
  Coding: 30363435363030303030554A3052384B3053
  ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
  ROD: EV_AirbaECUVWAUDI010_AU48.rod
  VCID: 3C70ACDFB77800DE41-8068
  Crash sensor for side airbag; driver side:
  Serial number: 6334MSME4146237BB
  Crash sensor for side airbag; front passenger side:
  Serial number: 6344MSME4142575EG
  Crash sensor for side airbag; rear; driver side:
  Serial number: 6352QSME3210503E5
  Crash sensor for side airbag; rear; passenger side:
  Serial number: 6362QSME400E2F0AN
  Crash sensor for front airbag; driver side:
  Serial number: 63732SME33145406P
  Crash sensor for front airbag; front passenger side:
  Serial number: 63832SME0A140C34Y
Address 16: Steering wheel (J527)  Labels: 8K0-953-568.clb
  Part No SW: 8K0 953 568 F  HW: 8K0 953 568 F
  Component: Lenks.Modul  H13 0013
  Revision: --------  Serial number: 90304HJS0001Z
  Coding: 000036
  Shop #: WSC 12345 123 12345
  VCID: 3D76A1DBA46209D676-8068
  Component: E221 - MFL  H02 0003
Address 17: Instruments (J285)  Labels: 8T0-920-xxx-17.clb
  Part No SW: 8K0 920 980 B  HW: 8K0 920 980 B
  Component: KOMBIINSTR.  H17 0224
  Revision: 00100000  Serial number: 9E3682JA8
  Coding: 2F0F080002002600010000
  Shop #: WSC 06325 123 12345
  VCID: 316E8DEB683AFDB6E2-8064
Address 19: CAN Gateway (J533)  Labels: 8T0-907-468.clb
  Part No SW: 8T0 907 468 P  HW: 8T0 907 468 K
  Component: GW-BEM 4CAN-M H09 0095
  Revision: EB500046  Serial number: 4600E08A148172
  Coding: 000303
  VCID: 4E94F61719C4824E9F-801A
  Subsystem 1 - Part No SW: 8K0 915 181 B  HW: 8K0 915 181 B
  Component: J367-BDM  H04 0150
Address 1E: Media Player 2 (R199)  Labels: 4E0-035-785.lbl
  Part No SW: 4E0 035 785 F  HW: 4E0 035 785 C
  Component: SG ext.Player H15 0850
  Revision: 00000000
  Coding: 010000
  VCID: 2B529F834A169766D8-807E
Address 37: Navigation  Labels: 4E0-910-88x-37.lbl
  Part No SW: 4E0 910 888 P  HW: 4E0 919 887 M
  Component: MNS ECE  H52 1060
  Revision: 00000000  Serial number: 333J$087627891
  Shop #: WSC 00860 210 94674
  VCID: 3B72AFC37A7607E648-806E
Address 42: Door Elect, Driver (J386)  Labels: 8K0-959-793.clb
  Part No SW: 8K0 959 793 E  HW: 8K0 959 793 E
  Component: TSG FA  H11 0250
  Revision:  Serial number: 0000007858864
  Coding: 011002204001410001
Address 46: Central Conv. (J393)  Labels: 8K0-907-064-46.clb
  Revision: 00002001  Serial number: 0115403164
  Coding: 011B062200390400002001
  Subsystem 1 - Part No: 8K0 951 177
  Component: DWA-Sensor  H02 0040
  Subsystem 2 - Part No: 1K0 951 605 C
  Component: LIN BACKUP HO  H03 1301
Address 47: Sound System (J525)  Labels: 8T0-035-223-BOM.clb
  Part No SW: 8T0 035 223 T  HW: 8T0 035 223 F
  Component: DSP Prem  H14 0400
  Revision: 00H14003  Serial number: 34814003475401
  Coding: 020101
  Shop #: WSC 12336 024 394758
  VCID: 3F8ADBD3AE6E1BC664-806A
Address 52: Door Elect, Pass. (J387)  Labels: 8K0-959-792.clb
  Part No SW: 8K0 959 792 E  HW: 8K0 959 792 E
  Component: TSG BF  H11 0250
  Revision:  Serial number: 0000007856494
  Coding: 011002204401410001
  VCID: 418EDD2BD89A6D3612-8014
Address 53: Parking Brake (J540)  Labels: 8K0-907-801-V1.clb
  Part No SW: 8K0 907 801 F  HW: 8K0 907 801 F
  Component: EPB Audi B8  H06 0070
  Revision: 00000003  Serial number: 00000000250997
  VCID: 326C82E76D3CC6AE9B-8066
Address 55: Headlight Range  Labels: 8K0-907-357.clb
  Part No: 8K0 907 357 B
  Component: Dynamische LWR  H01 0030
  Revision: 00000001  Serial number:
  Coding: 0000004
  Shop #: WSC 06324 000 00000
  VCID: 346084FF5728C89E89-8060
Address 56: Radio  Labels: 4E0-910-541.lbl
  Part No SW: 4E0 910 541 Q  HW: 4F0 035 541 L
  Component: TUNER EU/US/RDW H42 0620
  Revision: 00000000  Serial number: 336JY087608551
  Coding: 0000001
  VCID: 2E549697B904E24EFF-807A
Address 62: Door, Rear Left (J388)  Labels: 4F0-959-795.clb
  Part No SW: 4F0 959 795 N  HW: 8K0 959 795 C
  Component: TSG HL  H10 0251
  Revision:  Serial number: 0000007903119
  Coding: 010002204001210001
  VCID: 4480D43FC788781E39-8010
Address 72: Door, Rear Right (J389)  Labels: 4F0-959-795.clb
  Component: TSG HR  H10 0251
  Revision:  Serial number: 0000007903122
Address 77: Telephone  Labels: 4E0-910-336.lbl
  Part No SW: 4E0 910 336 M  HW: 4E0 862 335
  Component: Handyvorb2  H20 1130
  Revision: 00000000  Serial number: 00000005279388
  Coding: 0010920
  VCID: 2C509C9F8F18905ED1-8078
End-------------------------(Elapsed Time: 04:04)--------------------------
It's possible its not connecting to engine as you're using an out of date, presumed clone version of VCDS.
For the gearbox I suggest getting it to a specialist as it's not something you're going to be able to fix at home as its a mechanical fault. Out of interest when did it have its last gearbox service? It's due every 39k miles.
Less than 3k ago, well tbh been no sign of a fault whenever I've driven it so will see if it reappears, just seeing if anyone else had similar
