TTE340 Upgrade Turbocharger
Introducing our TTE340 performance turbocharger for the 1.8T. Offering 340PS and more with correct hardware & software, near Plug & Play Upgrade with fantastic response and OEM reliability. OEM+
Engineered & Enhanced
TTE340 is a evolution from our proven TTE300 and is based on a brand new Genuine BorgWarner K04 turbocharger, that we dismantle and set about upgrading as Turbo Engineers.
To produce a TTE340 K04 upgrade turbocharger we use a much larger BorgWarner 2283 billet compressor wheel, chosen because it is highly efficient and light in weight for fast response. This compressor also features BorgWarner Extended tip technology giving a compressor map that's very wide, creating extremely high flow for comparative size. We CNC Re-Profile the compressor cover in house to a optimized tight tolerance and finish to ensure maximum compressor efficiency is given.
The intake to the compressor wheel is a CNC milled billet piece with 58MM dia opening this gives a smooth transition from the intake pipe work to the larger compressor to lower turbulence and maximize velocity. The boost discharge outlet is also ported to again smooth the transition to the boost pipework to reduce turbulence.
Attention is given to increase the standard exhaust port size(40mm Dia approx) We CNC mill, porting the turbine housing exhaust and throat and entry size to approx 48mm diameter for maximum flow from a upgrade manifold and so improving efficiency to the bigger turbine used.
We CNC re-profile the exhaust turbine housing to optimized profile and gap to take a larger K04 turbine and shaft we use on this stage, this turbine is a Genuine BorgWarner item. We also give the turbine special curved clip of a specific amount. The clipping is a TTE grinding process to the turbine blade tips, curved to alleviate stress from process. Clipping reduces blade area, increasing gas flow and so reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost level's. This process also gives a secondary advantage of removing some material, lightening the turbine thus reducing rotational mass, improving moment of inertia.
Special profile 360 deg high performance BorgWarner motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. Actuator used is uprated sprung Genuine BorgWarner unit, fitted with our reinforced stainless steel clamps and hardware for trouble free operation. This also can be modified and set to customer needs and specifications if required.
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
Key Points
Genuine BorgWarner Housings
Genuine BorgWarner Billet 2283 Highly Efficient ET Compressor Geometry 6+6 (Inducer 46.50mm / Exducer 59.5mm)
Genuine BorgWarner K04 Trim 8 Turbine, Special Curved Clipped Blades (Inducer 50mm / Exducer 44.5mm)
TTE 58mm Billet CNC milled 58mm Intake Entry with 3 viton orings
TTE 48mm Turbine exhaust entry CNC milled and ported (matched for Relentless pro V4)
TTE Ported Boost Discharge pipe
Optimized Compressor Cover Machining Clearances
Genuine BorgWarner Uprated & Reinforced Actuator
Genuine BorgWarner Reinforced Bearing system
Dynamically Balanced (Supplied with test document)
Fitment As Original. Plug & Play (just needs supersize intake)
330+PS Capable
Pricing https://tteglobal.com/audi/s3/8l-1.8t/8/tte340-1.8t-upgrade-turbocharger
TTE 80MM TIP BILLET CNC ADAPTER TTE340/360
Designed for use with the CreationsMotorsporrt 3" (80mm) large bore turbo intake pipe ( http://www.creationsmotorsport.com/product-detail.php?pid=655 )
80.00 Euro inc VAT
Equilibrium
Key Points
330+PS Capable
80.00 Euro inc VAT
