TTE700 EVO Upgrade Performance Turbocharger TTRS 8S, RS3 8V.2
TTE Si
Site Sponsor
Site Sponsor
UK
TTE700 EVO Upgrade Performance Turbocharger 2.5 TFSI
Introducing our TTE700 performance turbocharger based on the original turbocharger to new higher output specification. Offering an upgrade power upto 700PS
Engineered & Enhanced
At the core of our TTE700 is a much larger TTE compressor wheel, chosen because it is highly efficient and creates an extremely high flow for comparative size. Re-Profiled compressor cover to optimised tolerance to ensure maximum compressor efficiency is given.
We CNC mill the exhaust turbine housing to accept a larger turbine and shaft.
Special profile 360 deg high-performance motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. The actuator used is sprung OE unit
Equilibrium
Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with a serial numbered balance test result document.
Product Highlights:
• Over 600PS on 98ron
• Original BWTS turbocharger as base part
• Thermally shielded exhaust housing and manifold
• Very early response
• Billet Milled TTE compressor
• Reinforced BWTS TTE actuator
• High Flow Turbine
• O-ring sealing
• Reinforced axial and radial bearing
• Proven TheTurboEngineers quality
• Made in Germany
TTE700 with & Unitronic software bundle: https://tteglobal.co.uk/audi/rs3/8v...evo-software-ecu/tcu-bundle?number=TTE10348.1
TTE700 : https://tteglobal.co.uk/audi/rs3/8v.2-2.5-tfsi/33/tte700-evo-upgrade-turbocharger?number=SW10032
Sharp-motorsport Upgrade Injector set required for max output. Link bellow
https://tteglobal.com/audi/rs3/8v.2-2.5-tfsi/186/sharp-motorsport-upgrade-injector-set
Our TTRS 8S 102 RON, 34 deg ambeint temps
Ha ha that must be laugh out loud funny on the road!
TX.
Reactions: TTE Si
D.H Automotive AUDI RS3 8v.2 with our TTE700 upgrade hybrid turbo fitted. (stock engine & transmission)
732PS 913Nm
MRC Software using Race 109 octane fuel
Graph shows comparison to a stock RS3 (red lines). As you see no loss in response
#TTEPOWER #TTE700 #FASTSPOOL #RS3
Testing our TTRS 8S TTE700 hybrid last tonight on an Autobahn 100-200 kmh
Pump 102ron fuel 1/2 tank. full weight
RS3 Saloon TTE700 D.H Automotive
Full weight, 99 fuel using MRC Software
100-200kmh 5.41 sec Dragy GPS timer
#TTEPOWER #TTE700 #RUNTTE
Reactions: Sandra
Reactions: RS5 JON
2018 TTRS 8S
spec:
SAR Intercooler, SAR down pipe with 2 X Catalyst, SAR Turbo intake, Upgrade injectors, TTE700 turbocharger, MTR performance software
15 degrees ambient temp, driver 115 kg, Full tank 102 aral, car series weight with OEM 20" alloys.
670 HP 800 NM 1.9-2.1bar
● 100-200 5,08 vbox corrected
● 200-250 4,66 Vbox corrected
More to come with some weight saving and mods...
#MTRPERFORMANCE #TTE700 #TTRS #RS3
Audi TT RS 8S 2.5 TFSI by BR-Performance Nederland
Stock : 400 Hp / 480 Nm
Stage 3 : 620 Hp / 768 Nm (low boost)
- TTE700 Turbo TTE INLET
- Forge Motorsport Competition Intercooler + Hoses
- CTS Turbo decat Downpipe
- Eventuri Carbon Air Intake
- BR-Performance Stage 3 custom remap +
Stage 3 S-Tronic remap + Rev limiter OFF
- Firezone 102Ron
#TheTurboEngineers #Forgemotorsport #BRPERFORMANCE
RS3 TTE700 MRC Tuning software
TTE700 Vs STOCK TURBO 393PS (green)
664PS is 99ron and octane booster
635ps is 99RON
Full weight, street time
Sascha’s TTRS 8s 680PS/ 735NM
5,2 Sec 100-200kmh
- Pgear Box gps
- 0Grad
- 100kg Driver
- Tank 50%
- 102 RON
- TTE700 turbo
- Upgrade injectors
- MTR Performance Software Motor/Dsg
- SAR Inlet hard pipe 90mm and K&N Panel filter
- Hperformance Intercooler
- Hperformance Downpipe mit 2 HJS Kats
- KW V3
- OZ Leggera 9x19 mit 245/35
Andy Tan RS3 hatch 8v.2 TTE700
1/4 mile 10.26 DRAGY
100-200 5.34
JB4 tuning box, 93 octane(98ron), wmi, forge hardpipe and silicone inlet
stock air box, stock exhaust, stock downpipe(decat), stock fueling
Drag brakes, r888, FR bC forged rims, forge intercooler
AUDI TTRS TTE700
715PS & 818NM 102ron
- TTE700 Turbo
- Upgrade Intercooler
- Suction to turbo
- Upgrade injectors
- Down pipe edited
Unfortunately, the exhaust gas back pressure
After loader too high (550 mbar).
There will be another update.
Not recommended for serial hardware!
RODS & PISTONS
Sar- Turbotechnik
TheTurboEngineers
MTR performance
#TTEPOWER
Reactions: Terminator x
RS3 TTE700 98ron MRC Tuning Bahrain
630whp
Unitronic Stage 3 ECU Performance Software for TTE700
Unitronic Stage 3 TCU Performance Software
AUDI RS3 8V TTE700 hybrid turbo, stock motor, trans, and clutches, stock fuel pump.
E85 fuel
Tuned for motor longevity and not max power
100-200 4.86 Sec
#TTEPOWER
TTRS TTE700 by BRPerformance
620hp 790nm
Stock motor
TTE700
Eventuri intake
Forge turbo elbow
Cts dp
Sharp Motorsport injectors
Wagner intercooler
98ron 10% ethanol
Few restrictions in the set up
Stock exhaust
Eventuri intake
TTRS 8S VMAX TESTING 102 RON FUEL
Autobahn
MRC Tuning in SouthAfrica producing epic results
AUDI TTRS TTE700 hybrid turbo
Owner Brendon was running 10.1 sec quarter mile repetitive at a recent event
100-200 5.49
0-100 2.70
0-200 8.47
675ps 793nm 102ron petrol 2.1 -2.0 bar
#TTEPOWER #MRCSA
AUDI TTRS TTE700 BY BR PERFORMANCE
2.1 BAR 102 RON 100-200 5.22 SEC
FULL WEIGHT, STOCK WHEELS
Congrats to Jason Rezo for his First ever 1/4mile run in his AUDI RS3 TTE700 hybrid in Australia tuned by internatonal auto-haus.
Jason managed a 10.1 @ 139mph low boost e85, full street trim and factory 19s wheels
Time to turn up that boost and get the 9
TTRS 8S TTE700 by AWESOME GTI / APR SOFTWARE
1/4 MILE 9.5 @149.50 MPH
100-200 DATA !!!
Congrats to Ronny Prill at RACE 1000 1/2 MILE Event Winner of class 3 upto 750HP (full weight, road tires, pump fuel)
1st. Ronny AUDI TTRS TTE700 MTR (720PS 102RON)
2nd. Chris VW Golf 7R 2.5 TTE700 MTR (715PS 102RON)
3rd. Daniel Porsche 991 Turbo ES700
Audi RS3 2.5 TFSI
Stock: 400.0 HP / 480.0 Nm
� � � DVX 632.7 HP / 802.0 Nm � � �
� 232.7 HP�
� 322 Nm�
Stage 3:
- TTE700 turbo
- Wagner Evo 3 Intercooler
- Integrated engineering Air intake
- Milltek Turboback
- Forge turbo inlet
- CTS charge pipe
- Upgrade mpi injectors
- 98 RON FUEL
Custom DVX Engine Remap 98 octane - Limited torque for stock internals!
Custom DVX DQ500 Remap
�Increased torque limiter
�Raised clamp force
�Faster shiftspeed
�Increased rpm
DVX 742.1 HP / 833.0 Nm on high boost
DVX 713.5 HP / 794.0 Nm on moderate boost
✅ 342.1 HP↗
✅ 353 Nm↗
Stage 3: (stock engine)
- TTE700 Upgrade Turbo
- Wagner Tuning Competition Evo 3
- Milltek Sport decat downpipe
- intergrated engineering Air intake
- Forge MotorsportTurbo inlet
- Sharp-Motorsport Upgrade MPI injectors
Custom DVX performance Engine Remap E85 high and moderate boost
✔Increased torque limiter
✔Raised clamp force
✔Faster shiftspeed
✔Increased rpm
Turbo info https://tteglobal.com/…/8v.2-2.5-tfsi/33/tte700-evo-upgrade…
DVX https://dvxperformance.com/…/rs3/8v-mk2-2017-/6149/25-tfsi/3
info@dvxperformance.be
#TTE700 #RS3 #CORN
Audi RS3 2.5 TFSi 8V MK2
DVX 634.6 HP / 756.0 Nm
30-35deg Ambient temps ☀️
✅ 234.6 HP↗
✅ 276 Nm↗
STOCK ENGINE Stage 3:
- Forge motorsport Intercooler
- Milltek decat downpipe
- Intergrated engineering Air intake
- Forge motorsport Turbo inlet
- sharp-motorsport Upgrade MPI injectors
Custom DVX PERFORMANCE Engine Remap 98RON
✔Raised clamp force
✔Faster shiftspeed
✔Increased rpm
Turbo info : https://tteglobal.com/…/8v.2-2.5-tfsi/33/tte700-evo-upgrade…
Eldar's TTRS 8S TTE700
During the Battle for Moscow event. Ran a 9.94 1/4 mile on the timing gear. Congrats
DRAGY DATA :
0-100 2.71
100-200 5.04
1/4 mile 10.05
Full Spec :
TTE700 turbo
Wagner cooler + downpipe
Milltek Catback
ie intake
Unitronic 3.5” inlet
18” Hoosier DR2 tires
Haldex controller
Weight reduction
18" rims with Hoosiers
Wmi
103ron fuel
Ecu+tcu software XXXX (Tuner not wanting to disclose)
#RUNTTE #TTE700
Ronny Pril in his TTRS TTE700 MTR software on 102 ron fuel
Taking 1st place at scc 500 this weekend in 600-750Hp class 4
#TTE700 #TTEPOWER
