Has anybody tried to flush the DSG software with the TVS flash tool? Is it easy to do? can you control settings in it or is it a hardcoded tune?
Yes, does not delete... they "read" the complete contents of the DSG into their systems over the internet, so they will have a copy of the original and will do what ever they make the updated version. Both, the original versions and the Tweaked (locked) Version will then be made available for you to download and keep locally and you/agent can overwrite the original and apply.
If its needed to fallback then the original is also there as well on your laptop and also in TSG as the firmware will be unique to your (VIN) - DSG box.
Whereas the official VAG version, will be generic (unlocked) for that specific version of the DSG across the globe.
I also looked at these devices, in the long term you’ll save money if you use it a few times over the lifetime of buying vw/Audi group cars. In the end I bought a unicorn developments one for the ECU tune and left the TCU. But even that didn’t work out and the map was garbage. So I would always visit a tuner with a roller to test it on.You can get the flasher tool it’s £200 plus the cost of whichever TCU you go for.
The one I enquired about was £685 just for the TCU.
Peron Automotive in Barnsley.
Is there a tuner that does real-time TCU tuning on the roller?
What was the total outlay in the end?OK, just finished installing the TVS stage 2+ using the flash tool. All in all, not too difficult to use, although not 'plug and play' either.
Ordered on the net via their web-site. Took just a few days to arrive.
Installation of the software on a laptop needed a special restart procedure to install the USB tool driver.
After reading the car TCU ID using the flash tool, sent the data plus a tune file request (a pdf form you fill) to TVS.
It took about 1 day to get the tune file from TVS. Programming the ECU with the tune was easy and took just a few minutes. TVS themselves are very responsive and friendly.
Wow! £900. You’ll need to use that a few times to recoup the money.1,015 Euros
¨Wow! £900. You’ll need to use that a few times to recoup the money.
