Facelift Tyre hole advice
RSS-S3
Forget or replace
Its very small and shallow, but I can see a couple of canvas threads.... please discuss.
DrEskimo
Take it to an expert buddy.
If it is bad, it definitely cant be repaired, it's too close to the sidewall.
Personally, I wouldn't chance anything when it comes to tyres.
Don76
If the cords are exposed you need to replace it. Imagine what it looks like when hot at 70mph!
Sent from my SM-G928F using Tapatalk
Don76
I've worked in tyres for 15yrs mate. Trust me, best to get it replaced.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
If you're replacing one then you need to replace two.
How have you been driving it?! That tyre is a scruffy haha
RSS-S3
No extreme driving here ............. :tonguewink:
Ironically this mark has appeared on a little trip out to the new forest on the weekend!
RichardT
Surely only if the other one is pretty worn.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
If there is anything more than 1mm difference between the tyres on the same axel, you should change both with the sensitive haldex.
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
Yeah yeah, like I believe you ;) I know how mine is driven from time to time and I am sat here wondering how the hell yours is driven to look like that :lmfao:
I tend to take it easy on corners thought to be honest, I see that isn't your style ;) Reminds me of the many salesmans loan cars I've driven, 1000 mile cars will well scrubbed in side walls :lmfao:
Seriously though, depending on the mileage don you should consider changing both. If anything did go wrong and Audi found there to be a big difference in the tyres, I'd expect they could turn the blame on you as they would tell you to change both at once.
JunkStory
I suffered worse damage on the sidewall, and was able to patch it up with rubber cement (found in a bike tire repair kit) which does an amazing job of gluing rubber back into a single piece.
However, I still replaced the tire a month later because I was going on a long road trip.
richinsoton
It's never worth compromising where safety is involved, for all you know it could look even worse from the inside & if your car is over 3 yrs old it's an MOT fail too. -
RSS-S3
They would have dam hard time trying to tell me a replaced tyre has caused damage to the Haldex system. (If that was to happen)
They would have to prove very conclusive/convincing evidence for that one.
desertstorm
Moderator
Staff member
Moderator
Personally I would definitely replace the tyre as what you can see on the surface is only part of the damage .
I wouldn't buy 2 tyres though, I am assuming that is a front tyre. With only 3K on the car I would swap the front and rear over on the one side.
Put the new tyre on the back on the side where the damage is and put the rear to the front. This should pretty much balance up the tread depths .
With 3K only on the clock the rears will be pretty much like new.
The depth of tread on tyres with Haldex cars doesn't really make any difference as it's not a full time system like the Torsen system.
You should have similar tread depths and tyre types across an axle to maintain balanced braking and traction.
RSS-S3
My thoughts exactly!
AudiNutta
Moderator
Staff member
Moderator
Gold Supporter
That's fair enough, I'd be the same.
