Planning the upgrade of the balance shaft and oil pump this weekend on my A3 2009 2.0 TDI, parts from KMB arrived today, and looking to follow the procedure as described in this post below:
One query - The method recommends turning the engine by hand to check that the gears have sufficient tolerance and are meshing correctly once new parts installed. How is the compression of the engine overcome when turning by hand as no reference is made to removing the glow plugs, for example, or in practice is this not an issue?
Worn oil pump hex drive shaft on MY09 2.0 TDI
did this balancer shaft / drive swap to my old 09 plate a4 3 years ago . i went and collected the kit direct from kmb ,at that time it cost me £150 exchange . most of the 170 engines have the balancer shaft setup . the parts from KMB Parts Direct are far far better than audi's own design. the...
www.audi-sport.net
