Upgrading xenon to curve lights bixenon
Rs3.jay
i miss my curve conering lights
Can you retro fit them
I have a 62 rs3 with standard xenons led lights?
Ash187
Gold Supporter
East London isn't far from me!
I can sort out the curve lights for you. will be after Christmas now though
Ash187
Gold Supporter
ok thats good, then only thing you will need is a replacement levelling controller that supports the cornering function
Ash187
Gold Supporter
your car already has the levelling sensors so no need to waste money on that.
you need part number 4L0907357B
Rs3.jay
Ok if u can tell me what parts to get then i will go get them. My car is a 62 rs3 with xenon i do not have any level sensors on front pass wish bone and not checked the rear.
So far i only have both front headlights with bulbs and modules under them.
Ash187
Gold Supporter
if you have factory Xenon headlights then you will also have the front and rear levelling sensors in place. you just need to upgrade the levelling module to the AFS type.
Rs3.jay
Hello buddy no i have not and iv checked iv defo not got no level sensor on the front wishbones.
Rs3.jay
I am gna strip out the glove box tomorow to check part num off the headlight control module and if its not the one i need i will orded new one as i cant find a second hand module. I dnt relly knw from what model and years cars have the module to locate a secont hand unit ??? Iv tried a few q7 breakers with no luck.
Rs3.jay
So a lil update. I got the new module and fitted it took the mill light off and i also checked a fellow rs3 with adaptive lights and it does not have level sensor on the front. Narther do some tt cars.
Ash187
Gold Supporter
According to ETKA the RS3 has has both sensors and the module.
T
T-800
Guest
Having been under the RS 3 at the weekend fitting the new rear drilled discs I can confirm it does have the above sensor fitted to the rear.
Rs3.jay
I have rear sensors and changed the module but i dnt have front ones. I asked ppl and no one replyed so i jus bought a ross tech cable. Cars in dealers getting new calipers discs pads. 2xrear door window black shines tringles as starting to corrode. A engine and gearbox ecu upgrade. The **** guards mod. Haldex upgrade
Will have a mess with it to see if i can jus get the module coded and works or need to install a front sensor but acording to tps guy he checked another rs3 and it had adaptive lights and did not have a front sensor.
Rs3.jay
right got my car back from audi 3 week theve had it feel ausome with new breaks and upgrades they done.
did a vcds check and this is the fault codes i have
Tuesday,27,January,2015,08:10:43:50049
VCDS Version: Release 14.10.0
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Control Module Part Number: 4L0 910 357 B HW: 4L0 907 357 B
Component and/or Version: AFS 1 H01 0010
Software Coding: 0000255
Work Shop Code: WSC 00000 000 00000
Additional Info: ----------- AFS-Modul links ----------- AFS-Modul rechts
VCID: 2B7BDCF98AC6B179EA9-807E
4 Faults Found:
01042 - Control Module; Not Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
02233 - Left Headlight Power Output Stage (J667)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:36
02234 - Right Headlight Power Output Stage (J668)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:36
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 0
Time Indication: 0
Rs3.jay
Data version: 20141022
Tuesday,27,January,2015,08:12:29:50049
Chassis Type: 8P (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 37 42 44 46 47 52 55
56 61 62 72 77
VIN: Mileage: 9020km-5604miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CEP) Labels: 07K-907-404-CEP.clb
Part No SW: 8P0 907 404 HW: 8J0 907 404 M
Component: 2.5l R5/4V TFSI 0050
Revision: F7H07--- Serial number: AUX7Z0L1FNM0AJ
Coding: 0103000C240F0160
Shop #: WSC 01236 785 00200
VCID: 70C10B95636092A19FB-8025
No fault code found.
Readiness: 0010 0000
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BH 300 011 Q HW: 0BH 927 711 C
Component: DSG DQ500-7A H05 1717
Revision: 00H05V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_AU35.rod
VCID: 3041CB956BE0D2A1DFB-8065
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 A HW: 8J0 614 517 G
Component: ESP MK60E1 0030
Revision: 00H60001
Coding: 0610199
Shop #: WSC 00861 210 98784
VCID: 2A75D9FD853CA87111F-807F
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0180
Revision: 000204 Serial number: 8P0820043BN
VCID: 79D736B1301AD3E9285-802C
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 R HW: 8P0 907 063 R
Component: BCM PQ35 H 110 0667
Revision: AG110667
Coding: 4E000A2FA005F0C0207041E02080085C42172BAA314DD928E4000E840041
Shop #: WSC 80093 222 69422
VCID: 43AB9459C2565939329-8016
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861206901980
Coding: 000103
Shop #: WSC 01236 758 00200
VCID: 48B18375FB707A61E7B-801D
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU0063DL9
Coding: 30314238303830303033554A305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 5285A11D052CC0B189F-8007
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000E630F1F/
Crash sensor for side airbag; front passenger side:
Serial number: 3582DRB40000E62CBA43
Crash sensor for side airbag; rear; driver side:
Serial number: 35128RB400006A170F4I
Crash sensor for side airbag; rear; passenger side:
Serial number: 35228RB400006A167DDW
Crash sensor for front airbag; driver side:
Serial number: 35547RB400006B7DAB50
Crash sensor for front airbag; front passenger side:
Serial number: 35647RB400006B7DB893
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0014142
VCID: 46AD8D4D31646C11157-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 983 E HW: 8P0 920 983 E
Component: KOMBIINSTR. VDO H03 0150
Revision: D0H03002 Serial number: 2241L002000375
Coding: 0001428
Shop #: WSC 06795 116 50998
VCID: 3C59EFA57FA826C1733-8069
Coding: 0001428
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 070312F2003201
Coding: 352103
VCID: 3B5BECB9BAA621F97A9-806E
Address 22: AWD Labels: Redir Fail!
Part No SW: 2K0 907 554 D HW: 2K0 907 554 D
Component: Haldex 4Motion 5010
Coding: 0000005
Shop #: WSC 31177 001 1048576
VCID: 2F43C8E9BEDECD59C61-807A
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H03002 Serial number: AUX7Z0L1FNM0AJ
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74C90785D778AE817B3-8021
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H07 0210
Revision: 0000013S Serial number: AUZBZ7MD214167
Coding: 0229725
VCID: 3449C78557F8EE81BB3-8061
2 Faults Found:
02005 - Coding Pin
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:48:37
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:48:20
Freeze Frame:
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0004860
VCID: 48B183753B707A61E7B-801D
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 243 3305
Revision: 00H22000
VCID: 3753F089468E05999E1-8062
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158129060878
VCID: 364DFD8D4184FC91857-8063
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0004860
VCID: 49B78671207A8369F85-801C
Part No SW: 4L0 910 357 B HW: 4L0 907 357 B
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000255
Subsystem 1 - Part No: -----------
Component: AFS-Modul links
Subsystem 2 - Part No: -----------
Component: AFS-Modul rechts
4 Faults Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:36
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:40:37
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0229725
2 Faults Found:
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:48:37
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 115
Mileage: 9021 km
Time Indication: 0
Date: 2015.01.28
Time: 13:48:20
Freeze Frame:
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F326015A
VCID: 71C70E91A86A9BA9905-8024
Subsystem 1 - Part No SW: 8K0 915 181 K HW: 8K0 915 181 K
Component: J367-BDM H07 0150
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000216
Shop #: WSC 01236 785 1012552
VCID: 42A5915D1D4C503139F-8017
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000216
Rs3.jay
This is what is says on else atm for normal xenon plus headlights.
J431 headlight range mod = headlight 14 pin connector
17=1
19=2
16=3
18=4
For adaptive curve headlights
J431 = headlight 14 pin connector
18=1
19=2
With pin 4 on 14 pin headligt needs power +
Pin 14 to ground
Pin 4 and 14 is for power to headlights module
Please correct me if i am wrong
