V6 Drain Diesel Fuel Filter - Help
RogerTDI
Every year its a good idea to drain the diesel fuel filter incase water has got in. Usually you undo a thread at the bottom of the filter. Is this the case with the V6 TDI - it's just very hard to get to the bottom or do you drain it by sucking out from the 8mm nut that is the air lock remover ??
Any thoughts much appreciated
