VCDS coding of RLFS sensor
Obvs
Hi everyone, just after a bit of advise, with the coding of the RLFS sensor. I have the sensor, a new headlamp switch for auto function and familiar with VCDS, although normally on my Amarok. Just got an A3 Sportback (8v) and want a little heads up to the correct coding/under which control units.
Main reason is for auto wipers and coming/leaving home to work in accordance with the daylight. Many thanks, Oli.
The factory default coding for the RLFS = 00006C. You will also need to code the RLFS in 09 - Cent Elect = Byte 6 > Bit 0-1 = 02 Light Sensor (PR-8N6) installed. From memory this is all you should need to do in order to have Auto lights and wipers work, other than setting your Switch to Auto and moving your wiper stake to the first position. Spray water or drum your fingers on the sensor to test.
CH/LH Lights:
09 - Cent Elect
Adaptations
(1)-Comfort illumination-Coming Home Verbaustatus = Automatic
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung = CH MMI Menu Active
(3)-Comfort illumination-Menueeinstellung Cominghome = Time for CH Lights to stay on (max 90secs)
(4)-Comfort illumination-Coming Home Leuchten = Lights to use in addition to DRL as CH/LH Lights
(5)-Comfort illumination-Coming-home Einschaltereignis = CH Lights Trigger (i have mine set to drivers door)
(7)-Comfort illumination-Leaving-Home Verbausstatus = Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP = LH MMI Menu Active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP = Time for LH Lights to stay on (max 90secs)
Channels 6 and 10 are for adjusting the CH/LH lights sensitivity. I have not completed any testing around these.
Have fun!
You may also want to activate the Exterior Lighting Menu while you are at it, if not activated already:
09- Cent Elect
Adaptations
(2) - Tagfahrlicht-Tagfahrlicht Aktivierung lurch BAP Oder Bedienfolge Moeglish = Active
Brilliant, thanks for the quick reply. I will attempt it next week and let you know how I get on, just waiting for gel pad that I forgot to order for the sensor. I'm normally a bit more adventurous but on older models it's always been in English for adaptions, seem more reserved not knowing German!
Cool cool :)
There is another adaptation which I am searching my notes for, which will add a Rain Sensor MMI Menu (on/off). Will post it up once I have found the notes but it's not needed in order to have everything working.
Stuffs are only in German at the moment due to Ross-Tech not getting around to updating the translations. Each new version of VCDS adds new english labels tho :)
Wow, you really are all over this. Updated to 15.7.3 but not used it much since.
Old post I know and taken me a life time to actually get around to this!
I've coded the RFLS into system, accepted the codes, been through the long coding and I have an error on the dash, and auto lights will not work?
930056 light switch fault, it comes on every time I put switch to auto? Have I been given the incorrect switch? Auto wipers work as they should so sure the sensor is all ok?
Part number of old light switch is 8V0 941 531 J, new auto switch is 8V0 941 531 AE.
Using light manually all works fine but auto is the same as if the switch isn't connected? Any help appreciated.
Reactions: DJAlix
Can you post up an autoscan? Do you have dynamic / adaptive headlights?
I've never done an auto scan so how do I perform?
It's a s line tdi with standard xenon headlamps, not led or adaptive as far as I know?
Reactions: DJAlix
From the main VCDS screen select the Autosan button and then on the next screen click start and once completed select save. Cope and paste the information in this thread and don't worry about any errors / malfunctions for the moment.
Reactions: Obvs
I will do this in the morning, thank you very much. Is it just of 09 you need an autoscan or does it automatically do all modules?
Reactions: DJAlix
Autoscan "scans" the whole car at high level :) Post up the whole lot if possible.
Hi Alix,
Here is the Autoscan as requested, hopefully you can find a hole in what I've done.
1st headlamp switch fault 929796 occured when I disconnected the headlight switch with the ignition on (I think anyway!)
Thanks a lot Oli.
VCDS Version: Release 15.7.4 Running on Windows 7 x86
Data version: 20160216
www.Ross-Tech.com
Saturday,25,June,2016,09:13:46:11220
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WAUZZZ8V3EA011459 Mileage: 69410km-43129miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5514
Revision: 83H22---
Coding: 02190012032501082000
Shop #: WSC 54981 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
ROD: EV_ECM20TDI01104L906021DS_AU37.rod
VCID: 79F9ABA5F8F286F639-802C
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61533000000539
Coding: 12F18AA224210A6D017B060541CC294851245080608294F2026100748508
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 7BF5B1ADF2CEB4E62B-802E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H13 0031
Revision: 20021000 Serial number: 00000000092519
Coding: 03100104002000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 6FED95FDB6B6D84697-803A
1 Fault Found:
459015 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 171
Reset counter: 17
Mileage: 66686 km
Date: 2016.05.13
Time: 11:53:03
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011315300818
Coding: 07000A42C24122DD03844004B31C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 77FDAD9DCEE690864F-8022
Slave 1:
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130518 041 0580
Serial number: 130529191313
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20877330
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 12 04 2013 00000607
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131081PQH
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000056886985
2 Faults Found:
929796 - Light Switch
U110B 00 [008] - No Communcations
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 17
Mileage: 69410 km
Date: 2016.06.24
Time: 20:27:24
930056 - Light Switch
B126A 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 17
Mileage: 69410 km
Date: 2016.06.24
Time: 20:27:07
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831315101921
Coding: 0000050001
ASAM Dataset: EV_EPHVA14AU3700000 002018
ROD: EV_EPHVA14AU3700000_AU37.rod
VCID: 387F6EA183785FFE86-806C
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01UANW
Coding: 98CCC0000C0000005C5400CA00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 4B95216DE2EEC466DB-801E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 002 905 13
Component: SideSensor_Df 001 0887
Serial number: 35767000000E58F03D00
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 2 - Part No SW: ----------- HW: 480 002 905 13
Component: SideSensor_Pf 001 0887
Serial number: 35867000000A69603D0X
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 403 105 13
Component: SideSensor_Dr 001 6149
Serial number: 3516502C31050660B21Q
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 403 105 13
Component: SideSensor_Pr 001 6149
Serial number: 3526502AD1050665623.
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 402 404 13
Component: FrontSensor_D 001 6149
Serial number: 3556502C9101233131AT
Coding: 2D2D2D
Pedestrian protection crash sensor; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 401 105 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502BD1050652313W
Coding: 2D2D2D
Pedestrian protection crash sensor; front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 401 105 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502BD1050652428/
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 8 - Part No SW: ----------- HW: 480 401 005 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502BB105065243D-
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 30051308490772
Coding: A418
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 970 N HW: 8V0 920 970 N
Component: KOMBI H03 2210
Coding: 27AC09002B8046000100AA00000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 479D1D5DFE862006FF-8012
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000633856
Coding: 030100040B0876005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear.rod
VCID: 3B7571ADB24E74E66B-806E
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 03 06 2013 C0272662
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051424490
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07051304080876
Coding: 00108E205C01040000001002
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 3F8D05BDA65668C647-806A
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D717FB5AC5A7AD655-8068
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 24051303110741
Coding: 001086205E01040000001002
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3E7378B9A15C61CE4C-806A
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 019E000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E1A795D4EAE2965D-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 874 A HW: 8V0 035 874
Component: MU-S-ND-ER 040 0370
Serial number: A7F00206130414
Coding: 01730300FF00000021111101000A00002F0001460100010002
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 3A7B74A9BD744DEE70-806E
Seat Adjustment Driver Side:
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9DG6015VY
Sound System:
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000022051300020988
End-------------------------(Elapsed Time: 03:37)--------------------------
Reactions: DJAlix
Few things to test here as it looks like:
  • Light Switch could be incorrect as the "AE" is for use with Adaptive Headlights.
  • Faulty Light Switch as it cannot be polled correctly by the car at the moment. It's still showing as a "J" Unit.
  • Incorrect Long Coding within 09 - Cent Elect.
This is what I would do first before going any further:
  1. Light Switch in Position 0, Wiper Stalk in OFF Position and Ignition in 1st Position ONLY.
  2. All Doors Closed but NOT locked.
  3. Make sure that 09 - Cent Elect > Long Coding > Byte 2 > Bits 0-2 are set correctly: If you have High Beam Assist (Light Assist) you need to select 03 from the drop down. If you don't have HBA you need to select 02.
  4. You need to Enable 09 - Cent Elect > Long Coding > Byte 7 > Bit 5 (Light Switch with Assistance Driving Light (ADL) Installed).
  5. Once 2 and 3 have been completed log off and turn off the ignition and wait for 5 mins.
  6. Turn Ignition to 1st Position.
  7. Reconnect VCDS and perform an Autoscan.
  8. When complete select save.
  9. Once saved select Clear All DTCs.
  10. Once completed Untick Display Freeze Frame and run another Autoscan, then save.
This will make sure that the modules are coded correctly and that any Historic DTC's / errors and or advisories are removed. The final Autoscan will then display any Current issues which need to be investigated. Post up the results before testing any lights please :)
You are a star, no warnings but I should have read the bit about not testing lights, I did not activate byte 7, bit 5.
I'm performing an autoscan now so will post details in a minute. Thanks again.
Reactions: DJAlix
Is all good, test away :) Just wanted to see a clean autoscan post steps in order to know 100% where we are at.
www.Ross-Tech.com
Saturday,25,June,2016,13:51:30:11220
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
Revision: 83H22---
Readiness: 0 0 0 0 1
Coding: 07000A42C24122FD03844004B31C07A80000000000000000000000000000
Slave 1:
Coding: 0A47F7
Slave 2:
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AE HW: 8V0 941 531 AE
Serial number: 05 11 2014 00000748
Coding: 0000050001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A418
Alternator:
Coding: 81
Sound System:
End-------------------------(Elapsed Time: 03:33)--------------------------
Reactions: DJAlix
Had to chuck the test map on quickly as laptop was dying, no warnings and will check later when dark whether they work.
Hopefully all ok but will let you know, and hopefully I've activated the cornering lights and coming home/leaving home correctly.
Thanks again and will be sure to let you know.
Reactions: DJAlix
