VCDS error code-Help needed please.
dt-tdi
Active Member
Hi all
I've had the error code below appear below last night which has prompted a DPF warning light on my 3.0 bitdi 2014 A6.
The error code will NOT clear.
Any ideas would be greatly appreciated.
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 P HW: 4G0 035 666 H
Component: H-BN-EU H52 1034
Revision: -------- Serial number: 189D10E7580174
Coding: 050101000003E5EF45848B3E00000003E00101020000000000
Shop #: WSC 02391 785 00200
VCID: 35674D559CE813E744-8060
Subsystem 1 - Part No: 8R0 060 884 BK
Component: EUR 2014 1703
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDED004AB7I
Subsystem 3 - Part No SW: 4G2 919 610 C HW: 4G2 919 610 C
Component: E380 BDT C7 H11 0204
Serial number: 90349NDI0001S
Subsystem 4 - Part No: 8R0 060 961 F
Component: CD-Database 5571
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Looks like your MMI firmware has been updated unofficially and that’s why you have this error.
dt-tdi
Active Member
I had a temperature sensor replaced on bank 1 replaced last week which sent the car into limp mode, once it had been replaced and the fault cleared all seemed to be back to normal, is there a possibility these faults maybe linked?
Any ideas how I can get this resolved?
DJAlix
Site Sponsor
Gold Supporter
The MMI / 5F is your vehicles Media System so doubt these are linked. This error can be removed, visually at least, by someone who knows what to do however it won't affect any functionality / usability if you leave it there. You will however have issues if your vehicle is in warranty or if you want to update firmware in future.
