Hi, I am normally found lurking around on the A3/8p forum, however I also own a 3.0 tdi Touareg. Listed below is the latest scan as EML has been on for a couple of weeks with no difference to the drive. Was wondering if someone could guide me in the right direction as to what is required to put right the problems. Although I have the VCDS cable I am not ofay with how to use it to its full potential. Help would be grateful as to what Open Circuit means on glow plug and what the Intake Manifold Runner Control actually is. Part no's would be an added bonus. Also in Central Conv- why have all those part no's come up if there is no fault? Cheers.
Monday,27,August,2012,07:03:00:54364
VCDS Version: Release 11.11.4
Data version: 20120807
Iain Muir RallyX
Chassis Type: 6N0
Scan: 01 02 03 05 06 08 09 15 16 17 18 19 22 36 37 46 56 68 76
VIN: WVGZZZ7LZ8D058130 Mileage: 91230km/56687miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
68-Wiper Electr. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 7L0 907 401 F HW: 7L0 907 401 D
Component: 3.0L V6TDI G000AG 0040
Revision: --H05--- Serial number: VWX3Z0H1709418
Coding: 0011779
Shop #: WSC 31414 790 00001
VCID: 2E5879A2BAC31968839
2 Faults Found:
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 254
Mileage: 89851 km
Time Indication: 0
Date: 2012.07.14
Time: 20:59:35
Freeze Frame:
RPM: 756 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Mileage: 89851 km
Time Indication: 0
Date: 2012.07.15
Time: 08:14:08
Freeze Frame:
RPM: 903 /min
Torque: 105.3 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.53 V
Duty Cycle: 24.5 %
Temperature: 15.3°C
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FA HW: 09D 927 750 FA
Component: AL 750 6A 0992
Revision: 00H61000 Serial number:
Coding: 0004456
VCID: 72E0ADD26E7B7D88271
No fault code found.
Address 03: ABS Brakes Labels: 7L0-907-379-MK25E1.clb
Part No SW: 7L0 907 379 L HW: 7L0 907 379 L
Component: ESP ALLRAD MK25E1 0303
Revision: 00H53001
Coding: 0004354
VCID: 42803D12195B8D08771
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 139 B HW: 5WK 485 04
Component: Kessy 6840
Revision: 68406620 Serial number: VWX3Z0H1709418
Coding: 0000232
VCID: 28548FBA98274758495
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7F61CC6821998A090F
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 AF
Component: CLIMAtronic R/L 4331
Coding: 0000530
VCID: 74ECABCA136F73B835D
Address 09: Cent. Elect. Labels: 7Lx-937-049-V2.clb
Part No SW: 7L6 937 049 AF HW: 7L6 937 049 AF
Component: J519 2000
Revision: -0004--- Serial number: --------------
Coding: 600001002B001C000000000000000000
VCID: 8004771AD7D7DF18A15
Address 15: Airbags Labels: 7L0-959-655.lbl
Part No SW: 7L0 959 655 HW: 7L0 959 655
Component: J234__37 VW8T 0250
Revision: 92012025 Serial number: 0039P0040N5Q
Coding: 0013111
VCID: FAF005F2B10B85C8EF1
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 F
Component: J527 3601
Coding: 0010012
Address 17: Instruments Labels: 7L6-920-xxx-7L6.lbl
Part No SW: 7L6 920 985 Q HW: 7L6 920 985 Q
Component: J285 KOMBI-INST. 7520
Revision: KHH06V02
Coding: 0007401
Shop #: WSC 00098 067 57207
VCID: 4B9E10362A114C40847
Address 18: Aux. Heat Labels: Redir Fail!
Part No: 7L6 815 071 G
Component: Standheizung E1MAC 0425
Coding: 0000000
VCID: 366851C2419321A8CB9
Address 19: CAN Gateway Labels: 6N0-909-901-7L.clb
Part No SW: 6N0 909 901 HW: 7L6 920 985 Q
Component: J533 GW-K-CAN TP20 7520
Coding: 57E2EF8D48056003
VCID: F0E427DAE377CF98515
Address 22: AWD Labels: None
Part No: 0AD 927 755 BG
Component: TRANSFERCASE 0126
VCID: 8102721EDBDDD610AEB
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0703
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 7L6 035 680 A HW: 7L6 035 680 A
Component: RNS-MID H04 1022
Revision: AB001001 Serial number: VWZ6Z7H7030092
Coding: 020004000400002200
ASAM Dataset: ------------------------- ------
VCID: 306467DA63F70F98915
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L6 959 933 A
Component: 1G HSG 0600
Coding: 0000065
Shop #: WSC 00098 210 83434
VCID: 4084371A10579F18615
Part No: 7L0 959 701 R
Component: Tuersteuergeraet FS 6303
Part No: 7L0 959 702 R
Component: Tuersteuergeraet BF 6302
Part No: 7L6 959 703
Component: Tuersteuergeraet HL 0202
Part No: 7L6 959 704
Component: Tuersteuergeraet HR 0202
Part No: 7L0 907 719 A
Component: Neigungssensor 0020
Part No: 7L6 951 171 B
Component: Innenraumsensor 0020
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 68: Wiper Electr. Labels: 7L0-955-119-V2.clb
Part No: 7L6 955 119 C
Component: J400__ Front Wiper 5301
Coding: 0001397
VCID: 3A7045F2758BC5C82F1
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 010208 046 0204
Coding: 00208933
Shop #: WSC 31414
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 F
Component: 0D Einparkhilfe 1107
VCID: 39725AFE748DCED026B
End ---------------------------------------------------------------------
Iain Muir RallyX
Chassis Type: 6N0
Coding: 0011779
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Mileage: 89851 km
Time Indication: 0
Date: 2012.07.14
Time: 20:59:35
Freeze Frame:
RPM: 756 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Duty Cycle: 80.9 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 89851 km
Time Indication: 0
Date: 2012.07.15
Time: 08:14:08
Freeze Frame:
RPM: 903 /min
Torque: 105.3 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.53 V
Duty Cycle: 24.5 %
Temperature: 15.3°C
Coding: 0004456
Revision: 00H53001
Coding: 0004354
Coding: 0000232
Component: ELV XXXX
Coding: 0000530
Coding: 0013111
Coding: 0010012
Revision: KHH06V02
Coding: 0007401
Coding: 0000000
Coding: 0000065
Coding: 0001397
Coding: 00208933
Shop #: WSC 31414
