vcds footwell lights?
lenny151
Does anybody know if you can permanently have your footwell lights on at night, if so how is it done via vcds
thanks
You can adjust the foot well lights from the MMI in terms of brightness or off from there. Maybe it is set to off?
The OP is asking if they can be default to on at all times, but they only come on when you open the door, don't they?
Yeah mate that's right just want them on when it goes dark if possible like the auto lights
I had same problem and recently I resolved!
Try this coding
Select 09 Cent. Elect.
Select Adapation
Select chalnnel (8)-Interior light; light configuration-Foot well lighting (About 240th to 250th line)
Adjust value Installed
You can change brightness of door and footwell light independently.
A
Reactions: lenny151
Mine are on all the time with the rest of the ILP. I agree - should be a VCDS setting needed.
12
3K
23
6K
