VCDS query
Bigandbald
Basingstoke
i have the cheapie blue ebay vagcom interface cable, my question is what do i need to do/ how much is it to get the right software so that i can clear faults and do logging etc??
i have vcds lite but as far as i can see it is useless in every way
so I register it and pay the £99 is that then the full version?
$99 but yes... full version... however... the caveat is its tied to the computer you registered it on... with a genuine lead you can install VCDS on anything and use the lead with it... the genuine lead acts as a 'dongle' to allow the full version of VCDS to work...
Possibly depending on the quality of your 'cheapie' cable, you may find that you get a lot of communication errors when using it.
I tried the eBay one and also ended up with one of the more expensive 'copies' and had nothing but problems with them.
I invested in the full genuine version from one of the authorised retailers and have not had a single problem since.
If your planning on using it a lot, my advise would be to save your cash and buy genuine.
Reactions: <tuffty/>
It's not the "full" version.
For your 99US$ you get a registered/working version of "VCDS Lite" which is locked to that computer, it's very useful but you can't reset service indicators / intervals + a few other things ... see here-> Ross-Tech: VCDS: Function Table
If you buy it and decide you want full VCDS in the future they'll discount the 99US$ off the price of a full cable.
Some of the eBay cables don't work very well.
I run mine in a Windows XP virtual machine on my MacBookPro and it does everything I need it to.
Liam
Reactions: AlexCW and Sandra
Ofcourse you can reset service indicators. You just dont have a big spastic-mode button on the front page to do it for you.
You just open the correct adaption channels and reset the values. It all used to be extremely well documented on their website, but i've noticed recently they're making the info harder to find as they introduce these automatic features in the newer versions.
I've used ebay cables for years, and NEVER had a problem. Sometimes the drivers set a silly latency which can cause connection issues but this is fixed easily with a few mouse clicks.
For older cars like the 8L and B5 A4's VCDS Lite is pretty much all you need.
Ah! Thanks, I stand corrected. It would be useful to know the adaption channels and values etc. if you have them to hand? before I go searching. Although it's a lot safer to have a big fluffy button to press. :)
Sorry don't think I answered your question properly the first time. A registered VCDS Lite is your cheapest option, it can be used to log and clear faults.
Ross-Tech: VAG-COM: Audi Service Interval Reminders
That usually works on most cars.
Theres other channels documented here that you can also tweak/adjust:
Ross-Tech: VAG-COM: VW Service Interval Reminders
Thanks!!!
Liam
45
3K
13
658
536
526
