I've always had soaking wet carpets on the driver's side after heavy rain and have tried all the usual tricks to alleviate the problem, such as completely removing the bungs in the plenum chamber, resealing the ECU box and generally keeping the whole area clean of leaves and other debris. I was surprised that even after all this the carpet has still been getting consistently wet.
So I've done some more investigation and found that the water is entering in an area just below the ECU box/behind the dash that's previously suffered accident damage and has been rather messily patched with big globs of sealant. We know that the wing on this side has been previously replaced but were not aware that the damage extended behind it. The sealant is not holding the water back and I've verified this by spraying the outside of the car with water whilst observing this area from the inside with an endoscope, and I can physically see the water coming in.
I need some advice on how to tackle this. In my mind it seems like the whole dashboard has to come out; at the moment access is impossible and I've hurt my neck and back contorting myself to get a look in there. Might there be access from the other side with the wing removed?
Photos attached and you can see my futile attempts to solve the problem by sealing the ECU box in from above with transparent sealant.
I'd also be interested to know if this is a normal way to repair this kind of damage that has unfortunately failed, or if it's a bodge.
