Hello guys, i have a Audi A3 8P Sportback manufactured in 2011 with some problems i like to fix.
(By the way sorry if my English is bad.)
Some months ago it started to act strange, there is a red battery light that lights up so now and then.
Symptons of the malfunction are, high beam keeps turning off after couple seconds and the computer is slow in the car.
If i try to turn on the turn signal sometimes it won't work or it turns on after a couple seconds. And when i turn of the turn signal the lights are sometimes still blinking a couple of seconds.
I also have VCDS and i think it has something to do with the Centr Electr module. Sometimes the malfunction goes away if it has not rained for a couple of days so i was thinking of a problem in the cable's. There are so much error codes i don't know what to do anymore. When the car is on without the engine running the system doesn't give any problems and works fine, but when i start the engine the problems come back. Can someone please help me out a bit what it might be.
Thursday,19,May,2022,22:59:56:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: License Plate:
Mileage: 101040km-62783mi Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 61 62 69 72
VIN: Mileage: 101040km-62783miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0011
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 G HW: 03F 906 070 G
Component: SIMOS10.11H02 9684
Revision: -------- Serial number: AUX7Z0J5FNF0MN CVN: FCB4FF8E
Coding: 00190090230401080000
Shop #: WSC 06314 123 12345
ASAM Dataset: EV_ECM12TFS02103F906070G 003016
ROD: EV_ECM12TFS02103F906070G_003.rod
VCID: 2643439F59E704B91B-8072
VINID: 9D196AAAA22025244004410520C23AA19F
3 Faults Found:
6060 - Body Control Module (Central Electric 2)
U0141 00 [044] - No Communications
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 34
Mileage: 101040 km
Date: 2022.05.19
Time: 22:39:36
Engine RPM: 622.00 /min
Normed load value: 13.3 %
Vehicle speed: 0 km/h
Coolant temperature: 95 °C
Intake air temperature: 48 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.116 V
Unlearning counter according OBD: 40
Engine speed: actual: 0 /min
7502 - Steering Column Control Module
U0212 00 [044] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 101040 km
Date: 2022.05.19
Time: 22:39:42
Engine RPM: 643.00 /min
Normed load value: 11.4 %
Coolant temperature: 96 °C
Intake air temperature: 49 °C
Voltage terminal 30: 14.015 V
10491 - Position Sensor for Heater Control
P304B 00 [101] - Electrical Malfunction
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 101040 km
Date: 2022.05.19
Time: 22:40:01
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Intake air temperature: 52 °C
Voltage terminal 30: 12.898 V
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 11422012092300FE880F04E990210050380800
Shop #: WSC 06314 000 00000
VCID: 04073917871B16A965-8050
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-047.clb
Part No SW: 8P0 820 047 D HW: 8P0 820 047 D
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 3169A0C3A8295301FE-8064
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 26000AB8002502C0207040E000008154421229AA004DC922E4008F800041
VCID: 387F9DE78B538249B9-806C
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
4 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:41:59
Freeze Frame:
Term 15 On
Voltage: 12.60 V
ON
ON
Term 50 On
OFF
OFF
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:41:59
Freeze Frame:
Term 15 On
Voltage: 12.60 V
ON
ON
Term 50 On
OFF
OFF
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:48
Freeze Frame:
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 6
Reset counter: 123
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:59
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
Term 50 On
OFF
OFF
Address 0F: Digital Radio
Cannot be reached
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB007MG8$
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FADC63B16DD25F188-801A
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000BA409B3Y
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB40000BA5CFA18
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005988C83S
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400005980A1BK
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005B5DECA7
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005B5DE9FA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000012
VCID: 75E154D31CC13F2162-8020
Subsystem 1 - Part No: 1K0 953 549 DB
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 K HW: 8P0 920 932 K
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2245J003006430
Coding: 0260104
Shop #: WSC 01102 004 104857
VCID: 3C7781F77F6BAE695D-8068
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 0302
Revision: H33 Serial number: 070610F1002020
Coding: E9807B4600010204002102
Shop #: WSC 00143 211 183112
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 123
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:34
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:29
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:29
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01003 Serial number: AUX7Z0J5FNF0MN
Shop #: WSC 47751 003 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0131220
VCID: 4999E82320B90BC1D6-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0131220
VCID: 4A9BD72F25BF00D9DF-801E
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 0302
Coding: 030B0864
VCID: 74E769D7D7BB262955-8020
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650231186
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: 428BFF0F1D8FD89917-8016
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 4385FA0B0295D1911C-8016
End-------------------------(Elapsed Time: 02:23)--------------------------
www.Ross-Tech.com
VIN: License Plate:
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 34
Mileage: 101040 km
Date: 2022.05.19
Time: 22:39:36
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 101040 km
Date: 2022.05.19
Time: 22:39:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 101040 km
Date: 2022.05.19
Time: 22:40:01
Revision: 00H30001
Revision: 00107 AF
Coding: 00DD13
4 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:41:59
Freeze Frame:
Term 15 On
Voltage: 12.60 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:41:59
Freeze Frame:
Term 15 On
Voltage: 12.60 V
ON
ON
Term 50 On
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:48
Freeze Frame:
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 123
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:59
Freeze Frame:
Term 15 On
Voltage: 13.90 V
ON
ON
Term 50 On
OFF
OFF
Cannot be reached
Coding: 0000012
No Faults Found
Coding: 0260104
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 123
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:34
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 83
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:29
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 101040 km
Time Indication: 0
Date: 2022.05.19
Time: 22:42:29
Coding: 0131220
Revision: 00H17000
Coding: 0131220
Address 56: Radio
Cannot be reached
Coding: 030B0864
Coding: 0131216
Address 69: Trailer
Cannot be reached
Coding: 0131216
