not sure 0-60 peak torque is at 2300rpm ao clutch survives also only smokes after peak torque kicks in im happy with resukt at the momentWow.
Random question - What sorta 0-60 you getting with your setup? That torque is amazing!
the pipe that had split on mine in the first post i had no lights on the dash but boost gauge would not show more than 5psi so wasn't holding boost at all then was smoking a lot under acceleration also jerking a lot nearly un drivableis it possible to have boost leak without limp mode?What are the symptoms?
In what way is car down on power ? If its not picking up very well then it sounds like boost leak so u need to test the boost hoses with smoke machine also if its making a dump valve kind off noise its definately boost leak, oil will take a good 6mo ths to clear out or can be cleaned out with cleaner as mentioned above in a previous comment also you shpuld make sure all hoses are inserted into pipes properly as could be leaking from there aswelHi guys
same issue i have with some oil in the xhaust due to a blownnturbo...all is fixed now, though i'm experiencing a serious loss of power n boost (replaced boost pipenthat a leak) so am thinking maybe its a faulty EGR...am i thinking in the right direction?
