WHAT BACKBOX FOR MY A3 3.2DSG?
granny87
HELLO! i have an a3 3.2 dsg standard at the moment but looking for an exaust thats not too loud and dont no whats the best remus was reccomended to me before any help appreciated
cheers
sub39h
Jetex or milltek
paddy
Remus
PaulAr
S3 (8P)
Cherrybomb:happy:
kool_bouy
I have put Milltek in mine. Sounds sweet. A bit deeper sound not loud though. U can only notice when u floor it really. Makes throttle more responsive and smoother Deffinately.
paddy
The milltek is a cat back and can sound really boomy, expecially on a motorway or long drive.
If you want a noise then go for the Remus but why not just try disconecting the town/country flap on the std exhaust first and see how you get on. Your not going to get a performance upgrade from either because the std exhaust is not restrictive anyway.
granny87
yeah i know but i would like a better sound from the v6 and remus is supposed too sound really good but ive not really heard any to be fair . cheers
clem2192
Paddy,
I've often considered doin this to my 3.2 manual, is it easy? (any step-by-step guides). Does it make a noticiable difference? Any downsides (fuel etc...)?
paddy
I have never tried it but i must make a little diferance or they wouldnt fit it. Its easy to disconect, its just above the tail pipe where it leaves the back box.
granny87
Paddy,
i did it today just unhooked the wire it sound pretty good aswell .
edition
Make sure you block the pipe up. If not it burns the vac. pump :)
Sarah's A3
MODERATOR V6 S3 Hybrid
Moderator
Jonathan, how do you mean it burns the vac. pump? explain??
edition
I think the vac. pump keeps pumping as it's open to atmosphere..... should be a closed loop....
The pumps are easy and cheap to replace tho. if they are the same as R32 ones.... :)
granny87
i just unhooked the metal wire and cable tied it so the flap inside the exhaust is open all the time . didnt touch anypipes?
paddy
Jonathan...I dont mean cut the pipe !! i mean as Granny says, just disconect the actuating wire from the flap. Its all still working as normal but just disconected from the flap..
edition
The way I did it was take pipe of actuator block it and re fit. Seemed to work ok.
edition
Have a search for R32 flapper mod. in google that will give you the idea. If not ask again and i'll take some pics.
It doesn't make much difference noice wise just means both pipes are open all the time.
