What bulb type used for ABS etc in dashboard / speedo?
lincoln_dj
Active Member
Hi, just wondering if anyone knows what type of bulbs are used for ABS, ESP, check engine etc.
Have took a punt on a cheap car (not the blue S3 lol) and some of the bulbs don't light up when turning the ignition on. I know for a fact some should remain on as it beeps at me and VCDS throws up an ABS fault (wheel speed sensor), and should probably also have the steering wheel bulb on too (can't complete steering angle cal).
Hoping to find out so I'm not taking my dash apart twice (having to put it all back because I dont have the right bulbs to hand)
Cheers in advance
LEE69
07 170 DSG
They are SMD leds very tiny. I bet someone has put blue tack or the like in between the led and the dials to stop you from seeing the issues.
lincoln_dj
Active Member
Thanks for the quick reply. I've just looked at how to remove the cluster and it's only a 2 minute job, so will have a look in a bit
lincoln_dj
Active Member
Just in case you wondered... found FOUR bulbs covered up with blu-tac - looks like the car was cheap for a few reasons!
bronco
Vancouver BC Canada
Hi, just wondering, how did you remove the cluster? Got any pics, links ?
Thanks,
