A3 T
Lord Of The Rings
- Joined
- Feb 23, 2011
- Messages
- 1,079
- Reaction score
- 16
- Points
- 38
Well guys its been one of those days
Before i start, As some of you know I've been living with these fault codes for a while now:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17522 - Oxygen (Lambda) Sensor: B1 S2: Internal Resistance too High
P1114 - 35-00 - -
Anyway.....
Recently my car has been getting good boost on the boost gauge but I'm not feeling much torque like i used to also my MPG has dropped a lot over the last few weeks.
So today i thought i would would clean the throttle body (as i have always done every 6 months or so) and for the first time clean the MAF sensor.
First i unplugged the connector on the MAF to find this:
I then VERY carefully removed the sensor from the housing (i managed to get a 5 point torx) and sprayed some contact cleaner on what looks like a little metal strip inside the MAF And let it dry for about an hour.
Once everything was fitted and connected up i started up the engine only to see this sign on the dash:
So i fired up VagCom and did a scan and I'm getting these codes:
P1118 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0110 1101
01314 - Engine Control Module
013 - Check DTC Memory
Notice that the:
P1114 - 35-00 - -
Has gone ?
Now am i right in thinking that the 01314 has come on because of the MAF error?
I also cleared the codes for the MAF and unplugged it and I'm getting the same 16486 code with it unplugged so do you think I've ******** up the MAF by cleaning it or do you think it could be the plug?
P.s i don't need links to ross-tech...lol
P1114 - 35-00 - -
Anyway.....
P1118 - 35-00 - -
P0102 - 35-00 - -
Notice that the:
P1114 - 35-00 - -
Has gone ?
