Jamsmoo
Apex ..obviously the ride tightens up under load
Alex Holmes
Unfortunately the car showed signs of PCV failure in the way home last night so ordered a replacement and gasket this morning. As expected the diaphragm in the pcv had split in multiple places...
Whilst i was in the area i decided to take the opportunity to fit the new valve cover gasket that has leaked since buying the car. It was that dry and brittle it was like plastic.
Then finished of with a little over due upgrade.
Bobbytea
Well… I’m pretty sure my A4 has a magnet for accidents.
Van driver though he could squeeze past me as I was about to reverse on to a customers drive… it’s not long been fixed since the sheep incident!!!
Hmmm… Not too much damage, but I think it’s a new wing and spraying to blend in.
I'm Just Rob.
Moderating or something,
Staff member
Moderator
Gold Supporter
Unfortunately the car showed signs of PCV failure in the way home last night so ordered a replacement and gasket this morning. As expected the diaphragm in the pcv had split in multiple places... View attachment 239672
Whilst i was in the area i decided to take the opportunity to fit the new valve cover gasket that has leaked since buying the car. It was that dry and brittle it was like plastic. View attachment 239673
Someones been a busy bee. :thumbs up: :yahoo:
That valve cover gasket looks marginally better than what mine was like....lol, and they go crusty quite quickly aswell.
DV diaphragm looks like it's been leaking for a while Alex , one split looks older than the rest, good job done chap.
Calipers are top stuff Alex , great colour too, and with 18" alloys they look massive, really fit the rim void well.:icon thumright::icon thumright:
making good progress now then.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Done a few bits today as well whilst the rain kept off this afternoon.
Oil and filter change, pretty mucky this time round so a worthwhile change.
Also removed my DV as i suspected a boost leak, nothing to be found a miss though.
Replaced the A6 snub mount bung with an OE bung I had in a box, not the best items but it's new and seems to have made an improvement.
Then spent a few hours swapping out both front driveshafts, been having some clonking on full lock and vibration at higher speeds, anyway all sorted now and lovely and smoooooth again with no nasty clonking.:yahoo:
so next week its cambelt/water pump replacement.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
forgot pics..lol
Both driveshaft inner cv joints were really worn and flopping around.
Alex Holmes
I was expecting it to be perished Rob but it was way worse than that. Had a right job removing it from the valve cover.
With pcv has made a huge difference to how the car drives now, it seems way smoother so all is rosie on the engine front now.
And yes really happy with the oem+ choice in colour. Just need to figure out a permanent solid fixing solution for the abs wiring and brake lines
I'm Just Rob.
Staff member
Moderator
Gold Supporter
ouch.. :scared2:
Fully
Member
Todays job on the Falcon - Replaced the Snub Nose Mount for a Powerflex version.
You can see from the pic it needed doing, as the old one was like an out of date marshmallow (all crumbly and nasty).
Very easy job when it was up on a 4 post lift.
Refitted.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
just a small job but a long overdue one.
Replaced the rear ARB bushes , original ones were a bit sloppy so time to fit some new ones, all nice and tight on the twisty back roads again. :yahoo:
Donfero
My DIY k04 build.
Got myself a S4 K04 CHRA, moved the internals to the k03 CHRA, Did some machining on the manifold, and now im ready to install. Wish me luck.
Sent from my RMX2170 using Tapatalk
Reactions: tr7
Donfero
My DIY k04 build.
Its amazing!!! A whole different level of power!!!
You won't be satisfied until you get a K04!!
Reactions: tr7
