What colours your car ????
Sent from my SM-A300FU using Tapatalk
It’s Lava BAD2612D 3FB6 44AA 9B0C BC297BCE6676
LED interior light upgrade. Looks so much better now. I've still got the side lights and number plate to do but it's p'ing down.
LED
Reactions: martin1984 and Jimbo d
I agree with martin. Black will suit your front end better. Looks really good as it is but I think that will finish it off.
I'm going to do the full mesh upgrade on mine at some point. Such an improvement over the squares
Yep the grille makes a big difference look forward to yours being done , now got to take bumper off again deep joy!
New rear springs and shocks are on. I managed to undo the inner bolt of the upper control arm on the side where my camber bolt is frozen. Would have been impossible to install the spring on that side without undoing this bolt.
In two minds on weather I should take the chance to cut the frozen bolt out and replace with new arms and bolts both sides as I'm only an exhaust hanger away from being able to drop the whole rear subframe so will be easy job.
Interestingly I found that both original rear springs had snapped at the first coil which explains why my Avant sat lower at the back.
Snow has stopped play for now just the upgraded motorsport ARB and poly snub mount to fit then it's off for alignment once the suspension settles.
Car HAS to be finished next weekend at the latest as the missus needs her car and I ain't getting the bus!! Currently entering week 4 of this suspension rebuild!
Reactions: Dan_Avant and martin1984
On another wet weekend I managed to fit my DV relocate then messed it all up so its back to the drawing board on that project...on a better note fitted my DRL LED kit and Morimoto Xenon bulbs, that went better than expected and without taking the bumper off, I don't have much skin left on my fingers now , a tight fit is not the word I would best describe the access to the nearside lamp top be honest , all most impossible but still doable .
Then on a down side ran vcds and had a whole raft of engine management errors logged.......i'll leave that till later now, so on a scale of 10 today has been about 4 , ten being very good..lol
I had the cam belt and water pump changed. Also replaced Egr valve with a Allard Egr delete kit
looks good, the shut lines may look better a little thinner , otherwise spot on .
Reactions: Nathan Russell
there are two adjusters which the bumper sits on, they control the height , they can be a pain to shift aswell as they can corrode or break.
they are either side of the grill.
I was going to remove my bumper over the weekend to do the headlamps but managed without taking it off, I did however manage to pickup two new mounts and rivets from my local tps on Friday, and they were in stock which I thought was odd as it is not something they sell everyday.
i'll keep them for another time now.
Ass6
they are not expensive either, I was expecting them to be over £20 each , but the two adjustable mounts with rivets came in at around £10 inc vat....bargain for audi parts.
New rear diffuser arrived today. Will be fitting it to the car later this year when I put the milltek on.
@Just Rob. sorry mate, nicked this idea from you
AD17DB30 0C39 4BAE A6FA 930DC1C8E92E
Ebay mate. £145 including delivery.
I’ll see if I can find the link. If I remember rightly it had an obscure title. The bloke had a few
he get's them on and off , more off though, they were never destined for uk cars , a few European and far off lands, so he is importing them or has access to a batch of imported items.
stuck in a brand spanking new rev "G" DV just too see if there is any difference between the "C" ,"D" and "G" , I've tried the first two with no obvious differences to performance, also a "G" I allready had , so now its 3rd time round with a new one to see if it's really is any better.
IMG 0721
Front bumpers finally been off today! Was easier than expected.
De-tangoed headlights with black inserts, black grille and front splitter fitted!
Then had to Soto out the little pond that had formed under the battery. Drain plug was completely blocked.
It’s now in the bin - wont be blocked again!!
Reactions: MartinHudson6 and martin1984
20180119 135421
Nearly ready to be fitted!! Just need to decide if I want fog lamps as well as an intercooler fitted!!
Reactions: Dan_Avant, Rob Avant, W2 NCC and 1 other person
Will be interested to see how it pans out, saw the debate in the other thread about this so would love another opinion thrown into the mix.
Sent from my Nexus 6P using Tapatalk
I hope there is some difference or I've just wasted another £35.00 , i'm not fully convinced yet that any of them have a really noticible improvement, but I could be wrong , we'll see .
E3CE9082 DF8E 4D9C 9D72 71E018F3716D
Fitted the first modification to my wagon that will actually make it go slower...
Reactions: martin1984 and Jamal Miah
While I was in my local TPS collecting the "G" DV I also picked up one of these.......a bit tacky I know but brightens up my bland engine bay a bit.....also a few extra BHP too..lol
IMG 0722
I rather like the white or grey stiching on the seats and headrest's chap, very trendy.
Thanks Rob, I believe it’s part of the optional Valcona leather pack. The stitching matches the central colours of the seats. Looked at a few wagons before I found one with all the toys and interior I liked.
My old bus came with the Valcona option but in all black, and I must say it is very nice too, very supple and comfy, not hard like at lot of leather finishes.
Westl1
