Evening,
Engine warning light has come on recently and I got the following error codes, but not sure which sensor is the faulty one. All help welcome
Address 01: Engine Labels: 06E-910-559-000.lbl
Control Module Part Number: 8E1 910 559 HW: 8E0 907 559 H
Component and/or Version: 3.2l V6 FSI 0040
Software Coding: 01040003180F0018
Work Shop Code: WSC 00000 000 00000
VCID: EBD337EECAEBD337EE1-80BE
3 Faults Found:
000310 - Oxygen (Lambda) Sensor B1 S2
P0136 - 006 - Malfunction in Circuit - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 3
Reset counter: 36
Mileage: 173826 km
Time Indication: 0
Freeze Frame:
RPM: 1440 /min
Mass Air / Rev.: 223.5 mg/str
Temperature: 60.0°C
Part Throttle
Voltage: 14.08 V
Bin. Bits: 00000010
004503 - Oxygen (Lambda) Sensor Heater Circuit: B2 S1
P1197 - 006 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 36
Mileage: 173856 km
Time Indication: 0
Freeze Frame:
RPM: 768 /min
Mass Air / Rev.: 109.0 mg/str
Temperature: 63.0°C
Idle
Time: 76.8 s
Bin. Bits: 00000010
008775 - Oxygen (Lambda) Sensor B2 S1
P2247 - 006 - Reference Voltage Open Circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 173880 km
Time Indication: 0
Freeze Frame:
RPM: 1280 /min
Mass Air / Rev.: 114.5 mg/str
Temperature: 36.0°C
Idle
Time: 25.6 s
Bin. Bits: 00000100
Readiness: 0000 0000
Ta.
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 36
Mileage: 173826 km
Time Indication: 0
Freeze Frame:
RPM: 1440 /min
Temperature: 60.0°C
Part Throttle
Voltage: 14.08 V
Bin. Bits: 00000010
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 36
Mileage: 173856 km
Time Indication: 0
Freeze Frame:
RPM: 768 /min
Temperature: 63.0°C
Idle
Time: 76.8 s
Bin. Bits: 00000010
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 40
Mileage: 173880 km
Time Indication: 0
Freeze Frame:
RPM: 1280 /min
Temperature: 36.0°C
Idle
Time: 25.6 s
Bin. Bits: 00000100
Ta.
