why large bore intakes such as B5 one work... on IHI's also 55g/s gains
badger5
www.badger5.co.uk
Site Sponsor
Car in question came in with an ihi vf34 turbo kit on it, done by a.n.other company.
.. started addressing the TIP..
As it arrived, remembering it was previously a k03 tip with glued on silicon to upsize it to the vf34's much larger intake..
3" Billet adaptor, custom TIP manufacture begins.
Mock up... ready to machine to VF34 dims
mocked up intake
[/QUOTE]
remember this vf34 was having to breath thru a small inlet... for k03!!
before decent size tip airflows below:
Code:
Group A:	'003				Group B:	'020				Group C:	'118
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Temperature	Load	Absolute Pres.
TIME					TIME					TIME
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	°C	 %	 mbar
154.51	1720	27.28	100	21	154.81	0	3	0	0	154.21	1720	24	88.6	1050
155.41	1720	28.22	100	22.5	155.71	0	3	0	0	155.11	1720	23	94.5	1110
156.31	1920	32.25	100	9	156.61	0	3	0	0	156.02	1760	21	92.2	1150
157.21	2320	45.36	100	15.8	157.52	0	3	0	0	156.91	2200	21	94.1	1220
158.11	2720	58.69	100	12	158.41	0	3	0	0	157.81	2600	21	95.3	1380
159.03	3120	79.08	100	9	159.33	0	3	0	0	158.71	3000	21	95.3	1540
159.91	3600	116.17	100	6.8	160.21	0	3	0	0	159.61	3440	21	95.3	1840
160.81	4280	194.64	100	5.3	161.12	3	3.8	0	0	160.51	4000	24	83.5	2510
161.72	5120	219.19	100	8.3	162.02	3	3.8	0	3	161.42	4920	27	84.7	2540
162.62	5520	213.53	100	11.3	162.92	3	3.8	0	3	162.32	5440	30	83.9	2540
163.51	5720	215.83	100	9.8	163.82	3	3.8	0	3	163.22	5640	34	82.4	2530
164.42	5960	216.22	100	9.8	164.71	3	3.8	0	3	164.11	5880	37	80.8	2490
165.31	6160	215.75	100	13.5	165.61	2.3	3	0	2.3	165.01	6080	40	80.8	2450
166.21	6400	215.25	100	11.3	166.51	2.3	3	0	2.3	165.91	6320	45	81.6	2440
167.14	6680	215.44	100	10.5	167.42	2.3	3	0	2.3	166.81	6600	48	82.4	2410
168.01	7000	216.22	100	13.5	168.31	2.3	3	0	2.3	167.72	6880	51	84.7	2370
and after making/fitting a decent intake to the turbo so it can breath properly
Code:
Group A:	'003				Group B:	'020				Group C:	'115
	RPM	Mass Flow	Load	Ign. Timing		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME					TIME
STAMP	 /min	 g/s	 %	 °BTDC	STAMP	°KW	°KW	°KW	°KW	STAMP	 /min	 %	 mbar	 mbar
14.7	1680	29.31	100	21.8	14.99	0	0	0	0	14.39	1680	82	1410	1030
15.59	1680	30.72	100	19.5	15.89	0	0	0	0	15.29	1680	94	1450	1090
16.49	1840	34.5	100	10.5	16.8	0	0	0	0	16.19	1720	97.7	1460	1150
17.39	2240	46.78	42.7	16.5	17.69	0	0	0	0	17.09	2120	103	1410	1220
18.29	2640	58.83	37.3	12.8	18.59	0	0	0	0	18	2520	110.5	1380	1350
19.19	3040	81.44	100	9	19.49	0	0	0	0	18.89	2920	126.3	1980	1470
20.09	3520	115.42	100	9.8	20.39	0	0	0	0	19.8	3360	157.1	2180	1770
20.99	3960	153.44	100	12.8	21.29	0	0	0	0	20.69	3840	190.2	2190	2150
21.9	4440	178.72	100	10.5	22.18	0	0	0	0	21.6	4280	191.7	2180	2290
22.8	4840	193.94	100	14.3	23.1	0	0	0	0	22.49	4720	191.7	2180	2290
23.69	5200	204.83	100	13.5	23.99	0	0	0	0	23.39	5040	191.7	2230	2270
24.6	5600	220.53	100	12	24.89	0	0	0	0	24.29	5440	191.7	2330	2280
25.49	6000	254.53	100	11.3	25.79	0	0	0	0	25.21	5880	191.7	2400	2370
26.4	6440	261.28	100	13.5	26.7	0	0	0	0	26.09	6320	191.7	2430	2440
27.35	6760	265.75	100	13.5	27.7	0	0	0	0	27	6640	191.7	2440	2450
28.3	7120	274.5	100	13.5	28.6	0	0	0	0	28	7000	191.7	2460	2440
29.19	7400	274.5	99.6	13.5	29.49	0	0	0	3	28.89	7320	191.7	2450	2440
30.09	7800	272.72	41.2	18	30.39	0	0	0	0	29.79	7600	190.2	2480	2440
Peak figure gains: previous highest airflow 219g/s @ 5000rpm @>1.5bar boost
Current airflows with badger 5 made 3" intake is 274g/s @ 7000rpm @1.4bar boost
55g/s gains!!
beachbuggy
Wow that's impressive £ per bhp that has to be one of the best mods available. Just goes to show what having the right additions to a BT makes!
S
sambryant
Guest
very impressive bill :D
the other tuning company should be ashamed of there work :(
