Jemis, try going out in the snow with your budget tyres on & then try & stop from 40mph.
Yes its a 4wd, but you will learn very quickly that they might get going easily enough, but (don't) stop the same as any normal car!
From real life experience I can safely say that only the idiots who have never driven with winter tyres on dismiss them.
Its a quattro you dont need fukin snow tyres wre not in iceland, just buy some decent tyres job done, I drove my S3 everyday through last winter with maxxis tyres which aren't my favourites but coped ok. If I was looking at at a S3 which had budget tyres on I'd never heard of I would have ran a mile these are high maintenance cars which need money spending on them so what else has been done on a budget?:
Not argueing,but winter tyres are worse for braking in wet weather than summer tyres!,and like i said in snow im not against them,just alot of money for not alot of snow!,and i cant get snow tyres for my 19's!,and cant get 18's,and 17' inch wheels won't go over the brakes so i cant try them if i wanted!Im with the guys above, 4wd gets you moving fine, but braking and going around corners is the same! my dad has a nissan navara, exactly the same issue - get off the drive and up the road no problem, try to turn and stop - never going to happen!! we stuck some proper tyres on and the difference was truely amazing!
I agree with a few other guys, dont knock winter tyres till you have tried them!
I work in a tyre depot,and have'nt came across many 18 inch winter tyres yet,mayby from germany,we have got some but not easy to find!,theres a auto car review on the braking cornering of winter tyres not in snow,the braking from 70mph was nearly 10 meters more to stop over summers in wet weather!,search autocar winter tyres!,apart from that they dnt do to bad!Incorrect. Once your below 7c summer tyres start to become worse at braking in wet weather than a good winter tyre. The reason is simple, summer rubber compounds quite simply get too hard in very low temperatures. Winter rubber is blended differently so it stays sticky at very low temperatures.
No idea what brakes your running, but given you can get 365mm RS4 disks/calipers under 18's you'd have to have something pretty extreme to require 19's for brake clearance. You'll find plenty winter tyre options available in 225/40r18.
Free contry is'nt it!,thought you can have a debait about things on asn!,i dnt want to argue either,it is boaring,and i was replying to someone else!,im just getting my point across that they are for those conditions!,but there are people saying on hear they have there winter tyres on already so they will be brakeing 10 meters longer to stop,food for thought!!*** mate!! Are you not listening!! That Autocar test was a specific test in temperatures ABOVE 7c it states that at the beginning. Of course they won't be as good, thats not the conditions they are designed for - nobody is disputing that.
Funnily enough Autocar recommend the use of winter tyres when temperatures are around or below 7c.
True!You should also bear in mind, that comparing a good tyre like the Eagle F1's on my car, with some budget wanli/linglong/triangle rubbish, would easily see a difference of over 10m in a wet stopping test from 70mph, even in the middle of summer. Yet many people drive around on these hopeless budget tyres year round...
Chatting to my MOT tester recently, he was saying he cant remember the last time he actually sold decent tyres, every set hes sold in many months have been budget tat. I had to buy my Eagles online, because none of the local garages could even give me a price on them. The whole reason this country grinds to a halt when some snow or ice comes, is the country is entirely unprepared for the weather, and are driving around with tyres that are not only not designed for winter use, but hopeless in the summer too.
