Yes I know that but why it goes down to same direction? It suppose to park other way meaning slightly up but not more down.
Windscreen not being changed. Might be previous owner took off scuttle panel.
Thanks mate. Don't know how to go adjust those. Any doc or link.
Crack the nut off on the arm, 13mm from memory. Use a wiper removal tool to get it off the spindle and readjust and tighten.
You don’t need a removal tool! Just put the wipes in service mode via the MMI, pull the wiper arm up and undo the 13mm nut and just wiggle the arm, it will come off easily. Reset the wipers to the parked position, turn off the ignition so they park in the lower position then reattach wiper arm in desired position and refit and tighten the nut. Job done!!
And if the arm is seized onto the spindle?
