if I get pads and brakes done from an indy using non Audi parts will it effect my warranty?
It may or it may not. If you have a problem with a calliper for example, and you tell them that work was done at an independant garage then the dealer may turn around and say it was the garages fault.
Example:
I asked my dealership to check the linkage on mine since it has trouble going into 5th sometimes. It had been like that from when I bought it 6 months earlier. Dealership said that because of the aftermarket clutch I had fitted by another garage they must have caused it. Despite me saying it existed before the clutch change they couldnt be ***** to look.
Not to mention the rogue engine bolt which somehow got into the head via the oil filler cap and trashed the exhaust camshaft, which they also blamed on the clutch change people despite the evidence I had which showed the symptoms also existed before the clutch change work.
This is the kind of **** you have to put up with when you get work done elsewhere during the warranty period. Incidentally, the cam shaft repair work cost me 3 grand when it should have been done for free by the garage.
Your call.
Just a bit. blame blame blame. That's all you get with these effin people
That said. The repair bill actually came to 6 grand but they "only" charged me half. 2 weeks after getting the car back the CAT then packed up as a result of the previous bad running. The dealer covered this in full, NOT the warranty who said it was caused by the camshaft problem and refused to pay out.
I suspect the dealer did this because I told them I would be taking them to court. After much deliberation and advice I decided it would be a lot of work and not convinced the court would award me an out right win, more likely 50/50 for which the dealer had already gone beyond that anyway (I paid 3 grand of what was a total closer to 7.5 grand for all the work)
