It arrives - The New Audi S3
A241687 small
  • Increased performance with 333 PS of power and 420 Nm of torque
  • Torque splitter and dynamic plus mode for agile handling
  • Expressive design and selectable daytime running light signatures
With a host of new features, the Audi S3 is more than just a product upgrade: Increased output, a torque splitter, and other technology highlights ensure strong performance and agile handling. Visually, the compact model reflects its increased dynamics with an expressive front design, a sporty diffuser, and a four-pipe performance exhaust system. The Audi S3 will be available at dealerships as a Sportback and as a sedan in the second quarter of 2024.
A240839 small
More performance: 2.0 TFSI with 333 PS​
With 245 kW (333 PS) and 420 Nm of torque, the S3 is more powerful than ever. As part of the product upgrade, the 2.0 TFSI2 1 receives an increase in output of 23 PS and 20 Nm more torque. The result is confident pulling power and strong acceleration. The S32 1 accelerates from 0 to 100 km/h (62 mph) in 4.7 seconds. Maximum torque is available in a wide rev range between 2,100 and 5,500 rpm. Top speed is limited to 250 km/h (155 mph). The engine and transmission also receive a sportier tuning: When at a steady speed and at low to medium acceleration in the part-load range, the preloaded turbocharger keeps at a constant rpm. In combination with the throttle valve, which is opened during overrun mode, this improves performance. The seven-speed S tronic now enables a more spontaneous take off, thanks to higher starting torque. This is achieved by compressing the clutch pack of the respective clutch more strongly. In addition, the shift time for gearshifts under full load has been halved and engine speeds are increased under partial load when the transmission is set to D which results in very good responsiveness.
A242260 small
More deceleration: larger brake disks​
The increased driving dynamics mean increased demand on the brakes. For this reason, the model upgrade for the S3 has been equipped with larger ventilated brake disks on the front axle, which are perforated to provide a visual highlight. The 18-inch steel brake now measures 357 mm in diameter and, at 34 mm, is four mm thicker than before.
The two-pistons calipers at the front are new too. They further improve braking performance, as do larger pads and larger friction surface of the disks, which have a significantly higher thermal and thus also a higher load capacity.
More expressiveness: progressive design​
With the model upgrade, the Audi S3 has an even sportier and tauter appearance. The hexagonal, frameless Singleframe features a new structure that is noticeably flatter and wider. L-shaped design elements accentuate the voluminous grille that, along with the large, angular side air intakes, highlights the S3’s dynamic character. A striking front spoiler, with two vertical struts inspired by motorsport, connects the two and further lowers the S3 visually.
A new bumper also makes the rear look more dynamic than ever. The structure of the Singleframe with its distinctive L-wings is reflected in the glossy black rear apron above the diffuser. It is divided into two parts for an S specific design that looks particularly sporty when combined with the vertical side reflectors that are a design feature of RS models. The dynamic appearance is rounded out by four tailpipes, another characteristic S-model feature. The optional performance exhaust system, which delivers a more voluminous sound, features a titanium silencer.
The vehicle’s progressive design is further accentuated by new expressive metallic finishes, including District Green, Ascari Blue, and Progressive Red. For the first time, Daytona Gray is also available in a matte finish.
A242265 small
More charisma: sharpened interior​
To match the more striking exterior, the interior has also been significantly sharpened. There are quite a few alterations here – from the shifter design and air vents to the decorative fabric inlays and new interior lighting. All these elements show precision in detail and emphasize the vehicle’s progressive and technical appearance.
The standard ambient light package plus in the S3 adds accents in the storage compartment in front of the shifter, on the doors, and in the footwell. With the model upgrade, the center console and cup holder now also feature contour lighting. One eye-catching new design element is the fabric panel in the front doors that was laser-cut 300 times. Its five segments are backlit by a light source in the door panel. The different sizes of the elements create a dynamic flow of light – which is also apparent when locking and unlocking the vehicle. This makes the illuminated fabric panel a unique design experience.
The interior of the S3 models features dark colors with a few silver accents. A black roof lining, stainless steel pedals, illuminated door sills with aluminum inserts featuring the S logo, and aluminum-style interior trim emphasize the vehicle’s sporty character. Artificial leather armrests and two-zone comfort air conditioning come as standard. Flattened at the bottom, the three‑spoke sports contour leather steering wheel features multifunction buttons and new chrome-plated steering wheel paddles. Sports seats with integrated headrests and pronounced side bolsters provide enhanced lateral support. In addition to Dinamica microfiber, a new technical textured fabric is available for the decorative inlays, as are aluminum and carbon fiber.
A241683 small
Reactions: Sandra and northpole
Pastimes and Activities for Audi Lovers
  • 304
With Audi set to join the Formula 1 grid in 2026, fans of this car manufacturer are getting excited for what’s to come. However, if you are one of the many enthusiastic Audi fans who can’t wait...
What Games can you drive your Favourite Audi Cars in?
  • 380
Cars play a big part in many video games, from classic racing arcades to more recent releases, allowing players to navigate, race, and pursue on screen. Games featuring cars like Audis range from...
The Audi 50 turns...50!
  • 374
Looks a bit like a Polo doesn't it? Well...
The Essential Audi Maintenance Checklist
  • 497
Like everything else, taking care of your Audi is essential. Maintenance and tune-ups keep your Audi going and protect it from expensive and trouble-costing repairs. Here’s a comprehensive...
How To Play Like A Pro: Easy Slots Cheat Sheets For Beginners
  • 170
Have you ever wished to win the lottery and go home a winner?
Even while slots are recognised for having a chance component, there are methods to play the game wisely and increase your enjoyment...
