vagcom faults
N80KRR
West Sussex
hi everybody, just wondered if anyone could help with these fault codes? as i dont have the money to buy the full version of vcds or clue what some mean.
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded
01331 - Door Control Module; Driver Side (J386)
49-00 - No Communications
01370 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
00962 - Shareware Version. To Decode all DTCs
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Shareware Version. To Decode all DTCs
01371 - Shareware Version. To Decode all DTCs
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01561 - Shareware Version. To Decode all DTCs
61-10 - Please Register/Activate - Intermittent
01562 - Shareware Version. To Decode all DTCs
00956 - Key 2
35-10 - - - Intermittent
thanks in advance.
Try user nhn he may be able to help you out.
Go to the Rosstech wiki you will find them all on these
only 1 id bother about is the top code others are nothing realy
16891/P0507/001287 - Idle Control System RPM: Higher than Expected. [h=4]Possible Symptoms[/h]
  • Malfunction Indicator Lamp (MIL) active
[h=4]Possible Causes[/h]
  • Throttle Valve Control Module (J338) dirty/faulty
  • Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
  • Vacuum Leak
[h=4]Possible Solutions[/h]
  • Check Throttle Valve Control Module (J338)
  • Check Wiring/Connector(s) from/to Throttle Valve Control Module (J338)
  • Check Intake System for Leaks
[h=4]Special Notes[/h]
  • When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
    • If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
Reactions: Sandra
Right got mate dropping his laptop off this evening which I'm going to use to try and clear some of these faults. I've got a new convenience module to code to my car as I think that's whats causing all the aggro with the door electrics not working on both sides of the car. only thing is i have no idea where to start, obviously I can read codes but don't want to mess it all up changing values I've found :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library which obviously helps with the numeric side of things but just wanted a bit of help using vcds. Gonna get father -in-law to look at engine fault hopefully he'll be able to play with the throttle valve module and get rid of the warning.
so your door locks windows aint working ?
have you pulled the rubber back between drivers door
very comon fault the wires snap and cause this problem
you have to look close as there usaly still intact but broke tug them you will find the broke ones if any
the TB fault iv found when iv had this on many cars needs TB RESET can be done with vcds if that dont work take it off clean it out then reset
Throttle Body
Prerequisites:
  • Ignition ON
  • Engine OFF
  • System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
  • Switch Ignition OFF.
854
855
762
