s4 exhaust.... same mounting as 170 tdi?????
outsideline
Lancashire
as above just fit my new s4 rear valance, now want the quad exit tail pipes to fill the holes.
will the standard s4 back exhaust system fit my car, it is also a quattro. already has an exhaust either side.
cheers
they are twin but they are single piped back to the manifold if that makes sence??
i mean its still a single pipe going into each back box just like mine.
But with the S4 having the V8 there is 2 pipes running the full length of the system making joining onto your exhaust very difficult as they only place where you the same number of pipes is right at the very back where it would be a cut and weld job and chances are turn out gash
if the standard s4 back boxes would hang on my mounts then i can do the rest, i have a good welder at work, once i have alined the tail pipes i will just drop the full system and cut and weld it where i need.
i just cant find out whether those 2 back box mountings at the rear are exact same place as the diesels??? its them what will determin where the tail pipes sit on the valance.
i have been quoted £300 for 2 custom back boxes but sure i can do it cheaper than that.
Ah i see then they could quite possibly fit as i had the single exit 2.0tdi 140 replaced with the twin exit 2.0Tfsi exhaust and was a perfect fit so i would say they hangers will be fine for the S4 back boxes as only one place hangers for back boxes can fit
