- Joined
- Sep 27, 2011
- Messages
- 805
- Reaction score
- 1,236
- Points
- 93
Could someone please tell me what these fault codes mean
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JN HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3174
Revision: 11H01---
Coding: 0104002C02072118
Shop #: WSC 00847 210 91033
ASAM Dataset: EV_ECM20TDI03L906022JN A01004
ROD: EV_ECM20TDI03L906022JN.rod
VCID: 7AF0890AFDC4789
1 Fault Found:
5293 - Throttle Valve Actuator Module (J338): Motor Circuit
P2103 00 [032] - Signal High
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 18
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AF HW: 0AW 927 156 G
Component: 0AW 20TDI RdW H01 0006
Revision: --H01--- Serial number: 0000000157
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A02005
ROD: EV_TCMVL381_AU48.rod
VCID: 77F6903ECED6651
1 Fault Found:
2225 - RPM Signal from ECU
P0727 00 [096] - No Signal
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 170500
VCID: 78F49302CBC86A9
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0134
Revision: 00002001
Coding: 011100
VCID: 30646B226338729
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
1 Fault Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 17
Reset counter: 84
The car is a 58 2.0tdi A4 Sline. The engine check light is on and a coil-preheater? light is flashing. I had the egr and throttle body cleaned but the lights are still on the dash.
The car runs fine and hasn't gone into limp mode. Appreciate any help
Revision: 11H01---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 0
Reset counter: 0
Coding: 170500
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Revision: 00002001
Coding: 011100
1 Fault Found:
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 84
