Fault code help on Audi A4 20 TDI 140 Cr
dandav1985
Active Member
Newcastle upon Tyne
Hello
Good mate of mine has just bought a 2012 Audi A4 2.0 Cr 140 tdi, all the bells and whistles.
He has been experiencing the car going into limp home mode and the flashing heater plug light with the engine like on.
So I have scanned it today and this is the result of the scan.
Saturday,28,March,2015,10:59:03:13746
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
Dealer/Shop Name: Danny Vag Com
VIN: WAUZZZ8K2DA070295 License Plate: ERIC
Mileage: 119140km-74030mi Repair Order:
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K2DA070295 Mileage: 119140km-74030miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCB) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 JP HW: 03L 906 018 JL
Component: R4 2,0L EDC H25 2842
Revision: 45H25---
Coding: 0A194012242401080000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018JP 003005
ROD: EV_ECM20TDI01103L906018AC.rod
VCID: 010FE26D903CB82961E-8054
6 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Mileage: 118820 km
Date: 2015.03.14
Time: 13:53:39
4124 - Sensor Reference Voltage B
P0651 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118820 km
Date: 2015.03.14
Time: 13:53:39
4881 - EGR Valve (N18)
P1440 00 [032] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118773 km
Date: 2015.03.12
Time: 13:06:18
4900 - EGR Sensor 1
P0405 00 [168] - Signal too Low
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 158
Mileage: 118773 km
Date: 2015.03.12
Time: 13:05:51
4891 - EGR Valve (N18)
P0403 00 [237] - Malfunction
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 33
Mileage: 118792 km
Date: 2015.03.14
Time: 12:10:46
4892 - EGR Valve (N18)
P0403 00 [104] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 118796 km
Date: 2015.03.14
Time: 12:20:48
Readiness: 1 3 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Revision: -------- Serial number: --------------
Coding: 161544
Shop #: WSC 06324 000 00000
VCID: 0009E7699336B1216E0-8055
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 13
Reset counter: 220
Mileage: 117880 km
Time Indication: 0
Date: 2015.02.23
Time: 11:45:56
Freeze Frame:
Hex Value: 0x6900
Hex Value: 0x4006
Hex Value: 0x1F09
Hex Value: 0x63B6
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 FB HW: 8K0 907 064 FB
Component: BCM2 2.0 H10 0602
Revision: 00002001
Coding: 03B10000000000000000
Shop #: WSC 06325 000 00000
VCID: 75E786BDDCF484894D6-8020
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
No fault code found.
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AC HW: 8K2 820 043 AC
Component: KLIMA 3 ZONEN H04 0036
Revision: D0000000 Serial number: 01060520121426
Coding: 342402E000
VCID: 6ADDA5C1854A5B71D04-803F
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DC HW: 8K0 907 063 AC
Component: BCM1 1.0 H14 0103
Revision: 03014001 Serial number: 00000030440202
Coding: 290000308034A7C00081000000001F1F001D020827080201000008000000020000000024000000
Shop #: WSC 46942 000 1048576
VCID: 73E3B8A5D2809AB9632-8026
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 130512 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
Component: G397_RLFS H06 0002
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD92ZMLB
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 55157 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 48993F49F3864961E60-801D
Crash sensor for side airbag; driver side:
Serial number: 6334MSME6F215528H
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME5D66354AQ
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME3915175EM
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME5F164B52R
Crash sensor for front airbag; driver side:
Serial number: 63732SME3C16435E4
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME33152376U
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20120516000399
Coding: 000016
VCID: 4FAB14551EE89E59A7A-801A
Component: E221 - MFL H03 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 982 B HW: 8K0 920 982 B
Component: KOMBIINSTR. H35 0540
Revision: 00000000 Serial number: NTE65DA5D
Coding: 3304080002012600010000
VCID: 336378A59200DAB9A32-8066
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 C HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H10 0025
Revision: 1Y030014 Serial number: 1441Y125078027
Coding: 00CF07FF00
VCID: 3F8B2495AE480ED957A-806A
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 F HW: 8T0 959 793 H
Component: TSG FA H09 0302
Coding: 011002204001410001
VCID: 4C910359EFFEA541C28-8019
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0023533808
Coding: 100000000001
ASAM Dataset: EV_RCEPSAU48X 008014
ROD: EV_RCEPSAU48X.rod
VCID: 34617BB99F0EDD81BA8-8061
1 Fault Found:
2305 - Function Restriction due to Start Voltage Interruption
U1410 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 221
Mileage: 118908 km
Date: 2015.03.17
Time: 09:08:23
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0175531761
Coding: 011B062200B900408020013680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 H HW: 8T0 959 792 H
Component: TSG BF H08 0302
VCID: 4D970E5D14E4AC49D56-8018
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 J HW: 8K0 907 801 J
Component: EPB-4 H01 0001
Revision: -------- Serial number: 10000000049199
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU48.rod
VCID: 366541B18972CF9184C-8063
1 Fault Found:
464128 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 118820 km
Date: 2015.03.14
Time: 13:53:39
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 056 D HW: 4G0 035 056
Component: Radio U STD H60 0094
Revision: AB001007 Serial number: 229E+0C7585037
Coding: 010003020100000001
VCID: 224D8DE13DFA4331584-8077
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 652 A HW: 8R2 035 652
Component: B-BN-EU H62 0175
Revision: -------- Serial number: 147DX0C7510529
Coding: 01010100000681ED01800B4E000000030000
VCID: 326D7DA16D1AD3B1A84-8067
Subsystem 1 - Part No SW: 8T0 919 604 HW: 8T0 919 604
Component: DU6 Basic H42 0098
Subsystem 2 - Part No SW: 8T0 919 611 HW: 8T0 919 611
Component: E0380 Bedient H01 0100
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 H HW: 8T0 959 795 H
Component: TSG HL H07 0302
Coding: 010002204001210001
VCID: 50A9172903D681A1BE0-8005
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 0302
End-------------------------(Elapsed Time: 02:49)--------------------------
Im I right for thinking its the EGR valve.
Any Help would be fantastic, Dont want him to buy a new EGR if it not the problem.
Cheers Dan
7K
19
3K
