Need some help
gussyldr
West London
I have a a3 2.0tfsi I've done a k04 conversion all was fine until I decided to fit an s3 cooler (my self) after looking at some guides thinking it can't be that hard so two days ago I fitted the cooler it's definitely not a one person job anyway every thing was going good till the end when I tried starting the car it wouldn't start? So I double checked everything and saw I forgot to connect this plug
Plugged it back in and started the car now my ECP and engine lights are on also oil pressure light comes on and turns off? While driving i got it scanned by a mate and two codes came back
18726/P2294/008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
Possible Symptoms
  • Malfunction Indicator Light (MIL) ON
Possible Causes
  • Wiring and/or connections faulty
  • Fuel Pressure Regulator Valve (N276) defective
Possible Solutions
  • Check wiring and connections
  • Check / Replace N276
16622/P0238/000568 - Manifold Pressure/Boost Sensor (G31): Signal too High
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31) faulty
  • Manifold Pressure/Boost Sensor (G31) faulty
Possible Solutions
  • Check Wiring/Connector(s) from/to Manifold Pressure/Boost Sensor (G31)
  • Check Manifold Pressure/Boost Sensor (G31)
I've triple checked intercooler piping my mate said I might have a boost leak
The thing is my car was fine before the cooler install no lights on the dash I've booked into http://audivwspecialist.magicallydesigned.com/ anyone heard of them? But they can't look till Wednesday Is there anything else I can check?
Check the plug on the turbo throttle pipe is connected
That's the one. Should be connected. Blow the water out with some compressed air in a can.
Hi guys ,
I have the same problem but after a car crash and some wires were cut. I replaced the hole wiring on the engine and changed the G31 sensor and nothing changed.
I start the card and the motor shuts down. After the error is registered , the car starts and runs but in limp mode.
Any brake thru with you problem ?
803
724
NHN
725
