Rustler burger
Hello,
I have a 53 reg 2.0 fsi A3. I’m after some information on how to diagnose why my fans dont come on when they should.
They dont come on when the engine gets hot ie the car will over heat. They also dont come on when I switch air con on (turn off economy mode) air con will work tho but will turn it self off after awhile (turning on economy mode) I then cant turn it off again, without restarting the engine.
I tried testing for a 12volt feed at the plug for the radiator fans but found nothing.
I have connected a 12volt feed straight from the battery to the connector plug at the fans and they both worked. So does that rule out the fan control module as this is behind the fan? And put it down to a wiring issue?
Any help appreciated!!
Russell
Russell
