How To De-Badge?
DannyBhoy
Age
41
Newcastle
Just about to take the plunge and de-badge my white 2013 A4 S-Line (getting rid of the A4 and TDI from the rear).
Am I right in thinking:
- Heat area with hairdryer to soften the adhesive.
- Run dental floss or fishing wire behind badges to remove.
- Use Goo Gone or Sticky Stuff Remover to get rid of the leftover residue.
Am I missing anything obvious? Anyone done it successfully and have any tips?
Reactions: daytonamart and V6_Man
Pretty much however, I didn't use hairdryer but just the dental floss behind the badges and took my time to remove them. And then used Autoglym Tar remover to get rid of the residue.
Reactions: DannyBhoy
Cheers Tashfeen - going to give it a bash after work tonight.
Should I be applying anything after the adhesive remover such as a wax etc?
Would be a good idea to do it however, I washed/polished the whole car after debadging and removing the adhesive just to make sure . The tar remover itself does a good job.
Reactions: DannyBhoy and 45bvtc
Slide a credit card behind the letters, ping them off. Then fudge wheel the glue foam off.
Dont really need any wire or heat to be honest.
Even brake cleaner on a cloth will remove the sticky icky.
Household items of WD40 first to soak and then a boiled kettle will do the majority .
Yes, I think that “wire” sounded a bit too nasty, though I’m guessing that you meant fishing line, ie nylon not steel wire!
Reactions: DrSasso
64
10K
14
6K
3K
