hussy
Leeds
Hi guys,
was wondering if anyone can recommend a garage within west yorkshire, front wheels are spinning up - rear are not kicking in, checked fuses which appear fine. Car has had a new front diff. I have read it may be the pump? but would rather take it somewhere reputable.
thanks in advance
Hi guys,
thanks in advance
Most likely blocked filter and pump, replace pump filter and oil.
Reactions: hussy
Have you had it scanned for codes? That should point the way to what's wrong and prevent any unnecessary expense :)
Reactions: hussy
Mine was spinning front wheels at 60mph, scary.
The fault was the haldex oil filter was blocked allowing the pump to gunge up and not be able to engage so no pressure to engage rear wheels when called for.
Audi do not see the filter as a serviceable part so no good going to the dealers.
Haldex oil and filter should be changed every 40k to keep the pump from going.
Oil around 60 quid, only a litre or so, filter around 40. Pump around 190-200 if gone. Service is doable on axle stands and needs vcds to run the pump to push filter out if it still operates and a pressure pump to get the oil in as the filler hole is right up under the car so you can’t pour oil in
If this doesn’t fix it the controller is next on the list 500-1000 if you get the latest from Awesome.
Reactions: James__S3 and hussy
Oh wow does seem scary what power is yours rubbing?
The website highlighter above seems very reasonable...
When you say the controller do you mean the haldex ecu?
Am I correct in saying the 8p comes with a gen 2 haldex?
Mines 320-350 I think not measured yet
The haldex guys really know their stuff
The haldex controller is screwed to the side of the haldex diff and can get water damage to the controller inside if the seal looks damaged or is loose - if this looks sound then it’s the pump
I think it’s gen2 for the 8p, there is an upgraded controller available if it’s knackered
Reactions: hussy
A pre facelift uses a gen 2 haldex and a facelift uses a gen 4 haldex.
Reactions: hussy
I was looking at this bit pricey
https://www.awesomegti.com/shop-by-...-performance-controller-ecu-generation-4-0by/
thanks for the info, yes that is indeed pricey!
i have the car booked in for diagnostics, hopefully its not the ecu and i can get away with a filter and pump change!
i am gonna pull the 4wd fuse i think its fuse 19 in the dash and plug it back after a drive, iv'e read this has worked for some..
thanks for the response mine is on a 58 place and is a facelift 8p dsg, think one of the very first ones, looking at the website i wasn't sure so this helps!
looks like mine is a gen 4
Just had mine replaced on my recently purchased FL S3. The car has a full Audi service history but as @mechanic69 has said above, they don't see the filter as a serviceable part, which for the sake of £40 is a bit silly. This eventually blocks and leads to a faulty pump. Just add a 1.5hr rate to the costs below and you're about there for how much a complete replacement would be. A good Audi specialist would change this filter as standard with a haldex service.
Haldex Filter = £39.58
Haldex Pump = £224.55
Haldex Oil = £33.82
Hope this helps
James
Reactions: hussy
Haldex Oil = £33.82
Hope this helps
James
thanks for the info!
all sorted now, not had the chance to fully test the car but can notice a different car was scanned and diagnosed with an issue with the pump. have changed it all over. hopefully this solves the issue!
22dfff 20181107 144423
old bits
Good to get things sorted hey?
Reactions: hussy
hi mate,
having similar issues with my S3 8P, spinning through gears pushing it hard and suspecting its a haldex issue. car doesnt feel draggy or anything like that and no errors or lights on dash... is there any way to differentiate the issue or any tell tale signs when its the expensive controller that has faulted?
hoping its just a filter or possibly the pump but unsure...
thanks
hi mate,
thanks
This error code may indicate the faulty controller
http://wiki.ross-tech.com/wiki/index.php/02248
Other codes are pump
thanks mate,
took motor to German car specialists in Stockport. it was a pump error, so new pump being fitted along with filters and oil change.
£450 all in for the work.
not great at this time of year - but could have been a lot worse.
thanks again for the input
Paul
Reactions: mechanic69
thanks mate,
Paul
Not a bad price given the parts are best part of 300 quid, hope it sorts it
