The Black Edition
J10NMM
Stoke
Spent the day in the sun and opted for something to brighten up the wheels
Reactions: Radford212
Fitted the RS grill the other day as well
Reactions: Bulldog and Rhyso
You should of painted the hub of the discs too makes such a difference when the cars clean.
C7C8A981 5617 41E2 932D D48D5C36581F
A5E17639 2ED7 427A B9AF 7028C53C46D2
Used a rust-oleum as an undercoat before the Zinc top coat
Reactions: BoringDamo, Matt Adamson, DickoB8 and 4 others
I used these as it cut out the primer process
B91F7E88 BF69 4675 9DD6 9020093DC1B3
0E66505B 3346 4512 BCF2 A491F8EC6719
Reactions: J10NMM
just picked it up after it's service and I'm £625 lighter
2 new tyres
Gearbox oil service
Air con service
luckily the main oil service & inspection was free
Reactions: DickoB8
2 new tyres
Gearbox oil service
Air con service
Ouch. The car looks good though. :)
Did you have to take your bumper off to get the grille installed? Tried myself and I looks like there are screws behind the crash bar?
Yes you have to remove the bumper to access the grille.
The grille is held in place by approx 20 clips; you’ll need a couple of pairs of hands and several flat edge screwdrivers!!
Yes, quite painful to change the grill. Don't forget to get the crash bar painted ( in black ) as they're normally silver and it will stick out.
You had to take the front end off to get to the screws behind th crash bar?
was able to do it without completely removing the whole front end, ones side was still attached
[photo=medium]10661[/photo]
then just loosened a few bolts on the other side
