Water in passenger footwell
Wagon Wheels
UK
I'm having water ingress to the passenger side footwell, usually when cornering. The other half isn't so pleased when her feet get a cold shower. It seems like rain water sitting somewhere then being displaced but can't for the life of me find the source. I've had the battery out and removed the rubber grommet which was holding a lot a water in there. That helped, but it still happens now to a lesser extent. Any other ideas??
There is another rubber grommet under the brake servo you need to clean that one out as well,
so you will have to remove the battery and tray to get to it.
Thanks for the tip! I managed to reach it just from underneath and yeah it was full of crud. Will see if that helps after next rain shower :)
Happened again today, so started digging by removing the glove box. Seemed to be coming down the outside corner and falling through a little rectangular hole on the plastic. Footwell carpet is soaking in the corner and insulation on back of the glove box too. So went on to remove the cabin filter assembly which is directly above that corner. Found a mass of leaves & crap which were absolutely sodden and blocking up the channel at the back which looks like is for any water in there to run around. Cleared it out and now trying to dry the carpet and glovebox lining! Hopefully that fixes it, we shall see. Also getting a new cabin filter tomorrow as the one in there was mank.
IMG 20200716 154452 IMG 20200716 154435 IMG 20200716 155443
I am sorry to say that looking at your picture I'm not supprised its leaking, not sure how long you had the car but it looks pretty grubby
under there.
We all know about the water that can build up in the bulk head under the battery and servo, so we have to check these,
well I do especially before the winter and clear out any leaves etc.
So let's hope you have solved it now, wet carpet can take time to dry and cause condensation.
Yeah i've not had it too long and i'm not one for going mad about engine bay cleaning, but saying that i've never had a car with so many hidden areas where dirt and water can accumulate!
Niagara falls is back. There seems to be a square hole right in the side of the cowl area and I can watch rain fall right off the dash into it. It has a plastic pipe coming out of the hole which clips onto the cabin filter assembly then goes nowhere else. I thought this hole must drain into the wing and out the wheel arch but now I don't think so. Anyone know what this pipe is for and if I can remove so I can plug up the hole? You can just see it in this pic. Cheers.
Sorry can't help bud. I did have this happen on another B7 of mine and had no idea how it was getting in.
Let us know if you do find the solution
Plastic pipe is for the battery vent, mine comes out of the battery, clips to the cabin filter housing.
Reactions: Wagon Wheels
20200801 115740
Plastic pipe is for the battery vent, mine comes out of the battery, clips to the cabin filter housing. There is a rectangular hole the pipe goes into in the wing, I'm guessing there should be a grommet there, mine is missing
Will need to check the parts list to see.
20200801 115740
Thanks norad, that explains a lot. My battery doesn't have a vent port, hence the plastic tube just hanging free at that end. Seems to be attached where it enters the wing? at the other end so can't just be pulled out. Would be interested to know if there's meant to be a grommet there? as I certainly don't have one, assuming that's what my problem is...
Yeah that's the thing I could be barking up the wrong tree entirely :) I've just put a glob of silicone over the hole, once the carpet dries (again) i'll test in the next rain shower.
I not sure if the water is coming in there, but it wont hurt to seal it.
I assume you have an updated picture of that area, hopefully looks cleaner.
I would check the metal closely to make sure there are no rust holes anywhere, and around the pollen fillter housing.
Just a random thought chaps, i take it the car leaks whenever it rains then, or just heavy down pours.
I'm changing my mind on that now lol. Heavy rain past two days sitting out in it and was still bone dry. Normal driving this morning was fine. Some spirited cornering this afternoon and wet again. Had the air con on blast and the water does seem cold. Its like it is dripping straight down off the circular plastic piece that's directly under the cabin filter assembly back of the glove box, but where is starting out from I've no idea. :blue:
Post a picture, could be from the aircon, maybe the drain is disconnected and running in the car.
This is the only part that felt wet to the touch:
I've been running with no glove box, so this time i could see where it starts on the carpet and only this area was actually wet. The carpet higher up and behind was still dry. It wasn't soaked through, so must have only just happened on that last drive. I've just looked at all the cowl area under the bonnet too out of interest and it's dry.
What you have highlighted in the picture is the blower fan, it's possible it has water inside and it's possible your heater matrix is leaking.
I would remove the fan but put a plastic under it first incase of water drops.
Do you have any misting on the windscreen when the fan is running, put it on demist to screen and check.
Never had misting on the windscreen. The AC/heat has always worked fine. I got a couple of small bolts out the bottom of the fan assembly, the third bolt is ridiculous to access, can barely get a finger tip on it never mind a socket. It dropped down a bit and there was a little moisture on the rubber seal, see pic. Looks like a b1tch to get the thing out as it all seems to be one unit that carries on behind the centre console?
Try running your car without the aircon on so the condensor isn't condensing.
It does sound like the outlet pipe could be wrongly routed. That way you can rule out the aircon being the issue.
Update :)
The week before last still present, then last week no problems and did a bit of driving with and without ac on throughout the week. Had an Audi tech friend go over it at the weekend, leak test from outside and went over everything from engine bay to under dash. Couldn't find anything and couldn't 'make' it leak! Only small thing he found was some junk in the draining tube, not blocked, but cleaned it out anyway. Had torrential rain since then and it's still dry. Not really sure if it's resolved! Time will tell I guess.
Well let's hope its stopped, all the heavy rain we just had will cause a leak if there is one.
Reactions: Charlie Farley and Wagon Wheels
Water leaks are a nightmare to diagnose. The carpet in my passenger foot well gets damp for some reason every now and again, not the accessory floor mat just the carpet underneath can't seem to figure it out but leaves a nice musty smell in the car the following moring
Fixed! It was the main heater box\matrix which was leaking. Replaced with a working used unit fixed the issue.
After the footwell drowning even more this summer, decided to start stripping it. Dash, steering wheel and centre console out then left AC on long enough you could just about see inside the main vent a little radiator looking part would leak once under pressure long enough. The water just made its way down the inside of the dash to the floor eventually. So found an entire second hand unit on flebay for 50 quid thankfully. Swapped it in and bingo.
Pic
just make sure you bleed the system fully or you will get an air lock stuck in the matrix and it's a real pain to clear, been there and its a pain.
