Hibiscus Red TQS - New Car, New Project, cars been here before though.
Getting busy this evening. Second hand marching ABS pump module arrived today. My plan being that I’ll detach the ECU from my unit, and bolt it to the other pump and motor unit. Hoping that this way, the ABS ECU will talk to my vehicle without the use of VCDS. I
l be honest. Apart from losing a screw and a nut into the undertray, everything has gone to plan. And I’ve just started the car, left it running for a bit and no ABS lights illuminated, so I’m guessing no diag issues. I’ve also pressurised the system with the larger input pipes connected, which purged the system. With everything tightened up, I pressurised it a second time, and no leaks. So……I’ll bleed all 4 wheels tomorrow, and cross my fingers I have brakes again.
Ive also changed the PCV valve again to a better quality unit. Somebody has told me a bad PCV will not help warm start failures. I was pretty surprised to see the stem of the PCV misshapen. Like the pinch clamp I e used has squashed it. Did not expect that.
Anyway, I’ll be busy again tomorrow night.
IMG 1459
IMG 1460
IMG 1461
ABS pump is fitted. Literally bought a used item of the same part number, removed my ECU from my pump, and installed on replacement, job done. Always a mission bleeding this car, had to do it twice again. But all good now. Changed the oil while it was in the air.
Since I’m at BTCC at Oulton Park tomorrow, thought I’d give it a polish today. Looking a bit more presentable now. I like this new front spoiler. Makes the front end look so much better. Also gave the engine bay a clean this time round, been ,earning to do it for a while. Cant stand dirty engine bays.
IMG 1486
IMG 1487
IMG 1488
Reactions: Gops and craigt1985
Been a while since I last posted, but been a tough couple of months in the new job, and just not had time. And that’s taken its toll on the B5 sadly. Airbag warning on the dash, steering wheel leather dilapidated, headlining sagging now, vibration from drivetrain, knocking on front suspension, exhaust banging like hell. So some remedial work before the MOT this week.
All the front suspension bottom arms, that I’d purchased over 2 years ago, I finally decided to fit. Not quite the easy job I thought it would be. Front arms came out ok, getting a new one back in was unpleasant without removing the rear one as well. But to remove the rear arm, turns out you have to drop the subframe. Fantastic when you’re not on a 4 post ramp. But, I’ve managed it, so we now have 4 brand new lower arms.
IMG 2713
Also had to drop the anti roll bar to fit the arms, so I swapped out the anti roll bar shackle bushes for brand new Delphi items.
I also managed to source a new undertray, since my old one had seen better days. My fibreglass fix has lasted a title while longer, but it was time to get a new one. Fits much better, much more solid.
IMG 2714
Found the source of my vibration too. To say I was alarmed when I removed the passenger side wheel is an understatement. Think the tracking had been out so badly that the inside wall has worn right down, how this tyre didn’t blow out is a minor miracle.i was on the motorway with this tyre only a week ago.
IMG 2704
Got a pair of Good Year Eagle F1’s to replace these.
IMG 2715
So now it’s just a case of visiting one of my customers this coming week. Inspect the prop shaft, see if it’s put of line anywhere, re secure the exhaust to stop it banging. And also fit a remanufactured ABS control Module which appears to have failed. I can for this myself, but I need VagCOM to programme it together with somebody who knows what they are doing.
Then it’s MOT time. And hopefully we’re good for another year.
Reactions: Gops, S3 Rav and S4 Muzza
So the visit to my customer went well. We had the car up on the ramps about 4 times in total with some test drivers inbetween.
First up, the exhaust was checked, and at first it seemed really solid. But it was extremely close to the rear diff cross member. So the exhaust mounting that attaches to the cross member was removed, and the holes elongated, so it could then hold the exhaust away from the cross member. This appears to work as there is no longer anymore contact.
Second up, the exhaust heat shield which had fallen onto the rear box was reattached and secured on the floor as intended.
Thirdly, the prop shaft was inspected. Both cv joints are running true at each end, but the bolts on the rear joint had come loose. So these have been retightened, and we also checked the centre spider and centre bearing. It appears as though there is too much lateral movement on the spider. Although I’m not so sure. So a decision has been made to take the car back in the future, take the prop off and send it to a local engineering company for a second opinion.
Lastly, the centre dash was dismantled, and the Airbag control unit accessed. As anybody who has done one of these before, you have to read the codes on the unit, find the 5 digit code unique to your vehicle, and store. Then swap over with your replacement unit. I got mine reconditioned from a place in Germany. Then recode the unit using the 5 digit side we stored, and reconfigure as a replacement unit. All done.
So now I have no airbag light, no exhaust noise, no prop vibration, wishbones all replaced, and new front tyres. So……..MOT time.
Have to admit, I’ve been playing with the idea of selling the TQS. As I’m really hankering after a DTM. But I know as soon as I sell this one, I’d regret it in a big way. Also I have no idea how much to ask for this one. I’ve spent a small fortune on it, I think everything adds to the car and doesn’t ruin it. I definatly don’t think there will be many TQS Audis in the UK that have had this attention. We shall see. What to actually ask for it, would be the biggest quandary for me.
IMG 2809
IMG 2811
Reactions: Gops
Geet stuff mate! I second keeping the car, there’s only 136 left on the road so hardly any at all!
Reactions: midas
136 is that all. I can see that number going right down in the next couple years. I do enjoy driving it. And I do love that you just don’t see them anymore. I might be growing weary of going through the job list, not sure.
I hear you mate; I feel the same sometimes, but I keep looking at the car and thinking I can't stop now and need to get it to a mint stage. I saw a normal 1.8 for sale for 3k the other day so these are definitely going up in value!
Not been on in a while now, been so busy at work. Plus I’ve been ill for about 6 weeks now. I’ve noticed @Gops and @Sandip have been posting updates, so going to try and find some willpower.
I’ve got a prop shaft to take off and get balanced, needs its 6 month oil service, front brakes seem to having an issue, spare rear diff needs sending off for rebuild, and then just for a bit of extra fun……it’s developed a misfire which occurs at idle but only after idling for about a minute. Perfect.
I did however get a day with no rain to wash it on New Years Day. First wash since September I think.
IMG 3576
Reactions: Gops and Sandip
Car looks mint mate! I hope you feel better as well bud!
I’m not feeling too bad, glad the chest infection has left me, just feel energy depleted.
Back to my customers garage tomorrow with an Air Mass, a Lambda sensor, and a throttle body.
We smoke tested the vac system the other day, no leaks on the boost/intake side. Obviously checked codes which only gave mixture wrong. All cylinders are firing correctly so no ignition fault, live read the coolant sensor which is all good. But when reading the lambdas live, the regulating reading maxes out at 25% and then just drops to zero which is immediately when the misfire starts. I believe this is because it’s running too lean and the lambda can’t read above 25%. So…..the lambdas either telling lies, or it’s getting a bad air mass reading, or somethings wrong on the breather system. Lots of checks to do tomorrow evening, sure we’ll get to it.
Going to leave it with him next week, get the prop shaft taken off, rebalanced, then see where we are.
lumpy idle / misfire is fixed. My customer ran a few tests, aided by an online guru he pays to be part of annually. This guy saw it as a challenge due to it being an older Audi and the kind of technology he cut his teeth on years ago.
Few tests and we eliminated the Lambda sensor, as with a disconnected Air Mass, the lambda was able to control the mixture itself Thus letting us know it was working. Quick swap of the Air Mass for one we knew was working, and the lumpy idle was still present. So attention turned to the breather system. Locked off the vacuum circuit serving the purge valve etc, and still the lumpy idle present. Started searching underneath the manifold, and eureka, my customer found a broken breather pipe. A half inch long split on a pipe. Locked this part of the breather system off, and the engine ran sweet, with the mixture returning to normal.
Had to invoke a bit of a bush fix, as the hose is different diameters at each end, so a length of normal hose couldn’t be used. Went with the bicycle puncture repair method. Cut a small length of surplus hose, touch both sides up, put some vulcanising cement on my broken hose, wrap the surplus hose round it and secure with a cable tie. Once refitted when dry, tried the car again, and engine was running perfect. Once up operating temps, the mixture was perfect +/- 3%. Brilliant.
We did however replace my throttle body this time round with a new one I’d ordered from AUTODOC some time ago. We also cleaned the original Bosch Air Mass with some JLM Air Mass cleaner.On the way home it ran great, except for a slightly lazy throttle. I’m thinking maybe I need to relocate the throttle cable, make it slightly tighter, and see if it improves.
Just goes to show, blame doesn’t always lie in a specific part failure, like a lambda or air mass etc. An air leak just needs to be discovered.
IMG 3670
IMG 3672
IMG 3671
I’ve not posted on here in a while now. But I have been getting on with things. The car was running well after the above tests found a bad breather hose (another one). I cannot find a replacement hose though, so the fix will have to stay.
Unfortunately, using the car for work, on my way home some absolute buffoon literally turned out on me as I was going past them. Evasive action left me with either hit the guy, or swerve and avoid. So I swerved. Unfortunately there was a traffic island in the middle of the road, and I went up it. So one of my new tyres was scrap, and I thought my wheels would be scrap too. But it survived……just.
IMG 4054
Bit of saving up, and I went with the getting wheels refurbished again, by the same place. My other half always said I should have had them done darker, so darker it was. Hmmmm, I’m not sure though if they are too dark for me. I’ve never liked black wheels, and these are little too close to black. Maybe it’ll get used to them. My centre caps in silver and black though didn’t help, so I made the very large expenditure of a brand new Genuine set from Japan. In Gold and Black. I think they look much better with those.
IMG 4524
IMG 4525
IMG 4526
IMG 4612
IMG 4620
IMG 4623
Went for a visit to see James Plant, and his awesome B5 TQS. He’s done a very good Touring Car tribute car, which I love. Knocking out nearly 500bhp, fully built engine. But James was good enough to let me have his Rieger front splitter which he no longer required as he fitted a full touring car splitter. I’ve always wanted the Rieger splitter so went to collect it straight away.
IMG 4394
IMG 4389
IMG 4387
IMG 4398
IMG 4681
Managed to find am APR Carnonio kit for sale as well, for the B5 TQS. I went through a phase of trying to obtain one of these, but realised most of these were in the US, so I gave up. Then this one popped up, so rude not too. Love the way they look and it is sealed off from hot air too.
IMG 4619
Came across something else I’d always wanted as well. A Eurotuning carbon fibre rear spoiler. Almost a duckbill type spoiler, but not quite. There wil those who like the B5 with a clean bootlid, but I’ve always like them with a bit of a spoiler at the back, but not one of the 90’s OEM spoilers. This one also matches my B-Pillar trims, and door mirrors. Keeping in the theme.
IMG 4683
IMG 4722
Well well well…….something I never ever thought would come along at this time. I said since I saw one at Oulton Park last year, that I would only even swap this for a B7 DTM in Sprint Blue. I’ve looked, and I’ve looked but condition mileage and price vary extremely wildly. But…..I’ve found one. Came along quite by accident. But it means I have to sell the B5. I put it up for sale on the TQS forum on Facebook and then couldn’t get any sleep that night. So many of my friends Say its an error and I shouldn’t sell it, it’s liked by many many people this car.
But, sometimes, you have to move on to a new project. So my Hibiscus Red Turbo Quattro Sport is for sale…….reluctantly.
I need the money out of this to go ahead and get the DTM. So I need decent money out of this. I’ve already had dreamers wanting to give me £2k. And I’ve already had the comments saying with the looney I want for it you could get an S4. In my eyes, if you want a TQS, you want a TQS. If you want an S4, you want an S4. Given the choice between one of the nicest TQS’s i know of (confirmed by Sandeep), or a dog of an S4, which it would be for the figure I want for this. Then I know which option I’d choose.
Anybody know of anyone looking for a TQS of this standard? Message me.
IMG 0576
IMG 0575
IMG 0577
IMG 0578
Reactions: Sandip
So it is with a heavy heart, that I’m putting the Audi up for sale. I spotted a DTM the other year at Oulton Park, and wanted one ever since, just had to fine the right one for me. And……I’ve found one.
So I may have just got the TQS to where I want it it……..but, I need the cash out of this one to put towards the DTM. Hoping it will sell quickly, but quite obviously I’m not wanting small numbers for it.
Anybody know anyone who’s looking for a decent one with some decent additions but still OEM.
IMG 0576
IMG 0575
DSC 0435
And…….its sold. . Been a fantastic B5 for me. I know I had some sues with it, but I’ve loved every minute of owning it.
Been and collected an A4 DTM today, which is also known on this site by fluke and coincidence. Thank you Jason.
Reactions: Gops and S4 Muzza
Car looks amazing mate! Sad to see it go but glad you got the car of your choice! Pop up some pics of the DTM!
This is the DTM, they’ll be more pics taken soon. But this was a pic from last weekend when I picked it up.
IMG 4886
Reactions: Gops
