Dave_Bayern said:
But yeah, Glenn, the reason for me it'll make a WAY better track day is the now very comparable performance specs but the way cheaper maintaining of the A3 chassis and the far more numerous products and the far, far more knowledge from other people with the Mk4 based car.
I'm not sure it will make the 'better' track car.
FWD will get to the limit of it's chassis before the 4WD car will...and that limit will surely be lower grip?
Better as in more fun, perhaps?
But faster lap times, all weathers? I'm not convinced.
The S3 is much more adjustable by way of things the user can to to set the car up, compared to the FWD A3.
As for an S3 running more usable torque, what are you basing that on?
Basically, you don't see too many A3 K03 cars running 320+ BHP...whereas it's easy to get, run and actually be able to use 320 lb-ft in an S3.
I found 330+ was getting to the point it was unpredicatable...but pegged to 315-320 lb-ft you could use all of the torque, all of the time.
What does your mapped K03S put out?
I'm going on my experience...but even with a LSD, 200+ lb-ft will be a problem in a FWD car...to use all the time, all weathers, without traction control (not the standard guff...but Racelogic or similar)
I am going to be taking my car to a proper FIA rolling road and getting a real print out but useable torque very much depends on what you intend to do with it and the K03s seems to deliver very well.
I'd say 'usable' torque is how much you can use, all day, every day, all weathers...which on a well set up S3, I think is about 320 lb-ft.
And with 320 lb-ft, the extra weight of the S3 coming out of corners, is negated somewhat!
As for the rolling road...as long as it is compensated to Din70015 (I think that's the standard) and seems accurate...gains are gains.
My S3 made 208 BHP and 199 lb-ft on Stars dyno when new...
30+ dyno plots later it was making 275+ BHP and 330+ lb-ft, every run, any day, any atmospheric conditions...on Optimax.
Lets also forget...big torque combined with shorter gears = quick accelleration...
It would be an interesting comparison, that's for sure.
Not looking for an argument...just looking for views!
