What have you done to your 8Y today?
MA3RC
Well-Known Member
Not sure if this thread will take off... But as the title asks, what have you done with your 8Y today??
I figured this would be a great thread for small jobs that don’t warrant a whole thread and good for people to share ideas :thumbs up:.
I’ll start things off with the fitting of my sunglasses holder, a nice addition and saves leaning over to the glovebox:
What about the rest of you?
  • Wow
Reactions: Tzsteve, VFR800Essex, SquidGame and 4 others
Reactions: chevy117
I have spent 4hrs to replace the front emblem to the black one. It was a pain to get the old one off. The OEM badge is clipped in solidly. I have the radiator cover removed to access the back of the front grill and broken the emblem piece by piece. There are total 10 tabs behind the emblem, my first attempt is to break all the tabs so i can use the plastic trim removal tool to pull the logo out but I was only able to access 6 of it.
Below is the pic of the 2 hrs progress, didn't intend to break the logo, but i was pulling too hard with the zip tie and the emblem broken into 2 pieces.
IMG 7079
And there are tabs still clipped behind the rest of the two rings. I struggled on pulling or pushing behind it for another hour. At the end I decided to cut the rings in pieces.:cower:
IMG 7086
All cleared!!!!
IMG 7081
And the black emblem on:rock:
IMG 7095
  • Wow
Reactions: JoMP, SquidGame, Mastachaz and 3 others
I also applied an abs gloss black cover to cover the grill surround chrome.
And also enhanced the fake exhaust tips.
IMG 7064
Will going to replace the back emblem to the black one on the weekend~
  • Wow
Reactions: SquidGame
As you can tell from my logo picture, I am working on converting my 2001 A4 Avant to a truck. All the body work except prepping for paint has been done. This took about 4 months and lot's of changes but it's almost done.
Bit random but can anyone send me a picture of the Audi A3 edition 1 35 tfsi (like the picture below) please. I'm trying to order my dash cam but I don't have my car yet to see . I need to check if it has that part the arrow points to. Please and thanks
Sent from my SM-G986B using Tapatalk
Replaced the back emblem to the black one, it took me about 1hr to clean up all the glue residue.
IMG 7136
Reactions: Tzsteve and SquidGame
Not 100% sure on what you are actually trying to compare but hope these help. Edition 1 35tfsi 2021.
4CF20965 3895 4F7E BA21 E94E7E73AAB6
91F911B8 DD41 4967 AED6 11DF9860D45E
Reactions: SquidGame and JustLulu
I added a dent to it this evening. View attachment 251992
I feel your pain mate. Someone decided that I did not need a gleaming example of an A3 and put something into the side of my rear while parked up. Luckily it is just the bumper so not tin work. I have still not decided whether to pay for a repair or go through the insurance
FC5BE682 D904 48B4 A4B2 1DFDF510E57A
  • Angry
Reactions: Barmybobuk
Sorry to hear this but they are correct that you're at fault I'm afraid
Live and learn, it’s all on track to be sorted through an Audi approved bodyshop, should be going in for repairs in the next 2weeks
Reactions: Brian Leslie
Excellent - Someone hit my S3 whilst I was visiting my Mum and didn't stop - £500 damage!!
Added this
Reactions: VFR800Essex and Brian Leslie
Just done a vinyl wrap over the plastic around the gear lever using black brushed aluminium, my first attempt.
Reactions: Tzsteve, VFR800Essex, EmilGH and 3 others
That looks awesome! Was it done without removing the trim?
No, I removed the trim but it was quite easy, I used a trim tool to remove the boot around the gear lever down the long side as it has two bits of plastic protruding which keeps in in position, then carefully pulled up on the plastic trim ( you can get your hand in once the boot is out of the way ) which is held by 5 clips then undid the two connectors from the ignition switch and the audio switch. When removing the two switches just be careful as they are each held on by three clips.
Thanks @creweaudiparts and finally installed the drivers side glove box
IMG 7407
Applied the headlight ppf and have all the chrome parts covered with piano black
IMG 7533
Reactions: mike60e, chevy117, creweaudiparts and 2 others
Dashboard wrap by a company in Holland with matt grey folie. No more scratches and fingerprints and pianolack. The red start-stop button is from Alie Express!
Reactions: Tzsteve, VFR800Essex, chevy117 and 2 others
TTRS 370mm front brakes :)
Reactions: himo, Stratman, Q5 TRS and 1 other person
All cleared!!!!
Looking great!!! I'm looking to do the same, can you give me some tips what was the "most" complicated? so maybe a hint will help, did you remove the whole grill? or you think I can do it without removing the grill? Thanks in advance
Reactions: chevy117
Today I installed warning lights in each door. I loved how it looks. Just spend 20 minutes, it is not necessary to take off the door panel.
20220617 211052
20220617 210416
Reactions: nutter2 and Kevmoz
Decided to use the auto park function on parallel park to see if it still works. 3rd time trying. First 2 very successful once it knows where you want to go. Let go steering just use accelerator pedal. Reversed in fine, asked me put to D when the car straightened itself out and it curbed the front rim. The car did, it didn't even said it was complete yet. I didn't think it would park literally 1-2 cm from the curb. So now I need to find some alloy touch up paint. Any suggestions? I've got the regular Audi non diamond cut ones
  • Wow
