Couldn't find a working method for this so had a play and came up with this....
Firstly, confirm why anti-pinch is kicking in. In my case, the drivers door window module thought it was 6% open when it was fully closed. This was visible under drivers door > live data > window regulator (in OBDEleven, 003 in VCDS).
Secondly, attempt to close the window a few times until the anti-pinch stop working (usually third attempt). Then go into output tests and try closing the window again (raise window regulator in OBDEleven). You should see that the regulator percentage is now 0%.
Finally, learn the new values. Open the window all the way by holding button. Let go and then press and hold again for a second. You should see in the live data that fully open is now 100%. Try to one-touch close the window and it should now be working again.
Using the output tests to try and close an already closed window would appear to be the only way to reset the values once they've shifted.
