Tuesday,26,July,2022,19:08:31:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZ1KZCW131849 License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZCW131849 Mileage: 220510km-137018miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Coding: 0403000C18070060
Shop #: WSC 01357 011 00200
VCID: 678BB967B36853736E5-8032
VINID: 9E69EAAAA05BA939C10C1204246E95CC2F
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 100.0°C
Temperature: 60.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.208 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.208 V
000771 - Cylinder 3
P0303 - 000 - Misfire Detected
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.208 V
004874 - Cylinder Disabling
P130A - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 19:00:27
Freeze Frame:
RPM: 3804 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 51.0°C
Voltage: 13.462 V
Readiness: 1010 0101
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 163B600D092580FB681306E890220181310800
VCID: 7BA3F517D3E0E7939AD-802E
No fault code found.
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 005982FBBA86844BCFF-8054
1 Fault Found:
9481200 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Date: 2022.07.25
Time: 09:37:51
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
Component: BCM PQ35 M 110 0651
Revision: 00110 AC
Coding: 48180A3A8825F1C0400800C0340001E44B511588536D8D20648000200040
VCID: 3A2D30139C5A1E9BC1B-806E
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 09091 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 160911 05 54 0403
Coding: 0230AD
3 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
03156 - Sensor for Anti-Theft System (G578)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
03266 - Control Circuit for Signal Horn
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0012
Revision: -------- Serial number: 62361125501601
Coding: 308003
VCID: 38292A1BA2560C8B37F-806C
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5RAAELEY
Coding: 00003958
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 313F173F41ACDDC3701-8064
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME66093461ZZZS
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME6C286062ZZZ-
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME4C1D5D3DZZZC
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME50405F78ZZZ-
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 BB HW: 5K0 953 549 D
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KIJ00165
Coding: 1082040000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 71BFD73F812C9DC3301-8024
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0519691
Coding: 820000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K6 920 972 HW: 5K6 920 972
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 470B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 73B3DD37FB30AFD3C2D-8026
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 190911F2002255
Coding: 350003
VCID: 3537232FB544F1E32C9-8060
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC053ACFA6E1B71B-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7660889965
Coding: 010000
VCID: 290FFF5F69FCA503B81-807C
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 F
Component: RNS-MID H42 3810
Revision: AB001001 Serial number: VWZ6Z7V0305622
Coding: 04000440040000920000
Shop #: WSC 05311 123 08193
VCID: 2F3B11475718CB33665-807A
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 220488 km
Time Indication: 0
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 313F173F4D2CDDC3701-8064
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 34311E2BB23EE8EB1B7-8060
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Coding: 0000948
VCID: 33331D37B730EFD302D-8066
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 220488 km
Time Indication: 0
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3537232FB944F1E32C9-8060
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 36352423A442FAFB253-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660893661
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 2615F46378628A7B953-8072
End----------(Elapsed Time: 01:35, VBatt start/end: 13.5V/13.3V)-----------
www.Ross-Tech.com
4 Faults Found:
P0300 - 000 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.208 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.208 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 18:58:35
Freeze Frame:
RPM: 798 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 60.0°C
Voltage: 13.208 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 220519 km
Time Indication: 0
Date: 2016.12.16
Time: 19:00:27
Freeze Frame:
RPM: 3804 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 51.0°C
Voltage: 13.462 V
Revision: 00H31001
Revision: 00001004
Coding: 0000004002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Date: 2022.07.25
Time: 09:37:51
Revision: 00110 AC
Coding: 009795
Coding: 0230AD
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 39
Mileage: 220473 km
Time Indication: 0
Date: 2016.12.15
Time: 09:37:47
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 308003
Coding: 00003958
Coding: 1082040000
Coding: 820000
Coding: 470B00
Coding: 350003
Coding: 000000
Coding: 010000
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 220488 km
Time Indication: 0
Coding: 0000692
1 Fault Found:
Revision: 00H20000
Coding: 0000948
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 220488 km
Time Indication: 0
Coding: 0000144
Coding: 0000144
ROD: UHVNA.rod
